Today my freezer went warm as well as my refrig. Everything in the freezer had to be thrown away. There is air coming through the vents, its not cold though.
HI, Can you hear the compressor running? Does it click like something is trying to start but can't? It sounds like the compressor is not running. The compressor should have a 5 year warranty. They are having problems with these compressors so, you might want to call Amana and see if it is under warranty. I hope this gives you some help. Please let me know if I can assist you further.
Thanks
Vic
If you remove the rear cover on the back outside, you can tell if the compressor is running.
Did you notice any frost build up inside the freezer?
Ok, If the compressor is running and both of the fams are running, you should have cold temps. If there is no frost build up or no ice building up, you should have cold. Is there any xhill at all?
It sounds like the compressor has gone bad and not pumping like it should.
Sorry.......... can fix appliances, just can't spell...... hehe
it is the compressor then. Is it under five years old?
Some have date on model # label
If you call the 800 # on the label, they can tell you.
You might have to pay the service cll and labor so I would check on that.
My pleassure. Please feel free to rate my responses to you so that others as well as myself will know hw I am doing
Thanks
Good Luck!!
Vic,
The fan on the inside is working- we can feel air coming out, but its not cold. I do hear something running (whether it is the compressor or fan I am unsure). There are not any strange noises.
Thanks~C
there is no frost. took a bit to find the right tool but we removed the back cover. the compressor seems to be working. its vibrating
not sure what xhill is?
could it be the thermostat control?
oh, chill?
warm/cool air- definitely not cold or even a little chilly
yes, I believe so- or at least close to it. wonder if there is a date on the inside of the fridge
Would I just call Amana on this one? Thanks so much for all your help with my silly questions
thanks so much for all your help. I really appreciate it
I have and thank you
