Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Fridge stopped working suddenly
Yesterday my fridge simply stopped working.  I don't know if this could be related, but we lost power the night before.  It runs as if it is fine, but it no longer cools either the fridge or the freezer.  Every 3 minutes or so, it kicks on and there is this slight buzzing noise that lasts about 5 seconds and then clicks off.
Any ideas??
  • 473 Answers
Re: Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Posted on Oct 22, 2007
0 characters
3 Points
Fridge freezer
Hi Joanna, The link below is a web page showing a few different solutions on why your freezer has suddenly stopped freezing, I hope this helps......CHEERS..
Apr 17, 2016 | Refrigerators
Freezer and fridge suddenly stopped cooling
Is the compressor running? If not check the condition of starting capacitor/relay.
Mar 18, 2016 | LG LFC21776ST 21 CF French Door Refer Cab...
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
I have a hotpoint fridge bottom freezer and after I had filled the freezer with my shopping yesterday, it started making a shreeking noise, I thought maybe it needed defrosting, which it did, so I...
If both section are not working as required then its compressor fault.The noise you noticed must be from compressor related parts,that are fan,the motor and relay.But If freezer is getting over cold and friezed and fridge section not getting cold then Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Hotpoint FFA45 Bottom Freezer Refrigerator
Whirlpool ff 400 elite, probable pcb fault
compressor is running 10 menites after 10 to 15 minites compressor start
May 09, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Lost power, now fridge won't work.
check all the fuses maybe blown up due to high amper of sudden power resume.
Aug 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
249 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
