Question about Panasonic DVD-LS91 Portable DVD Player with Screen
  • 21 Answers
Are those line on the desktop / screen itself or within a program to play a movie. If those lines apear on th screen itself than the probem can be related to backlightes (laps around your screen) or inverter ( a part of backlights system). More possible those lapms needs to be exchanged. Please give more details.
Posted on Oct 22, 2007
0 characters
3 Points
How can you get a movie to start playing without the remote? I have lost mine and pressing the play button just goes to the menu which loops
After the movie loads and shows "play" highlighted. And only then,press the stop button and then press the play button and the movie should play...hope this helps.
Dec 30, 2009 | Sony BDP-S350 Blu-Ray Player
My dvd player pdv 709 wont show the movie .it shows half
my Portable DVD Player just stop playing movies. i put a movie on and it want read or it will start the movie snd just stop and want play no more
Oct 23, 2009 | Durabrand PDV-709
It goes to a black screen with a yellow sign with a arrow on it pointing down, it also has a green, yellow, and red bar at the stops at the red.
Had this same issue. Your probably trying to play either Crank2 or StarWars. Talked to Panasonic Tech Support and they said not enough memory to play disc and gave me these instructions:
"This movie title requires that an SD card of 128MB or larger to be inserted into the BluRay player prior to inserting the BD disc each time you watch this movie.
The SD card must be formatted in the BlRay player before use. (Do not format the SD card on your PC)
Formatting an SD card in the player:
-Insert an SD card (1GB or higher) into the SD slot of your BluRay
-Press [FUNCTIONS], select "other Functions" and press [OK]
-Select "Card Management" and press [OK], then follow the on-screen commands
Once formatting is complete, leave the SD card in the SD card slot. Insert the movie disc into the BluRay player and it should play normally."
Personal note, the bar graph that has always stopped at the red will hesitate for quite a while and then the rest of the bar will fill up and BD will begin to play.
Oct 04, 2009 | Panasonic DMP-BD30K Blu-Ray Player
JVC - XV-F80 DVD Player
Either the disc or the player likely need a good cleaning. Clean the disc with a soft cloth, clean the player with a good cleaner disc.
Feb 26, 2009 | JVC XV-F80 Multi-disc DVD Player
Unable to play a DVD movie
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
Dec 09, 2008 | GoVideo DVR4300 DVD Player/VCR
JVC XV-N212 DVD player - unlocking region code
It is not a permanent hack, you will have to to it over for every movie you put in.
1. When "REGION CODE ERROR" shows on screen after you've input your wrong-region DVD you push "ON SCREEN".
2. When the DVD-menu is showing push "ON SCREEN" again and another DVD-menu will appear.
3. Move the arrow over to the clock and press enter. The menu asks for "TIME" and you write 0:00:00 and push enter.
4. You will now see the menu for the movie. Remove the DVD-menu by pushing "ON SCREEN" once. You can now watch the movie.
Don't think theres a pernament one for this player yet but i'll try and post it on here if i ever find one. Sorry.
Oct 15, 2008 | DVD & Blu-Ray Players
Tv guardian settings
OK I FOUND IT!!! IT'S 1234, when the parent control screen shows up press the play button then enter 1234 then press play again!!! The movie plays then!
May 08, 2008 | Disney Princess DVD Player
Jvc dvd player
seems like you put an NTSC dvd movie in there and the machine is set to Pal or the other way around. you need to program your computer to multi region setting. check the website for the unlock region codes. good luck
Mar 16, 2008 | JVC XV-S302 DVD Player
Multiple vertical colored lines on DVD player screen
check this out
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Panasonic DVD-LS91 Portable DVD Player with Screen Logo
238 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
