Question about Samsung DLP HL-P5663W 56" TV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Samsung lcd 46 inch shuts off after 20 30 minutes
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
Posted on Sep 05, 2009
My 50 inch samsung tv shuts off suddenly. Cooling fan does not seem to work.
If a fan is not working the set will not turn on . Replace the fan.Is lamp ok?
Sep 01, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although FixYa.com (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
Mar 18, 2010 | Samsung HLR5087W 50" Rear Projection HDTV
I have a 42" Samsung DLP that makes noise that sounds like it's coming from the fan. The sound starts after the TV has been on for 20-30 minutes; it's a winding type sound and continues until after the TV...
These models usually suffer from a bad color wheel. You will know that the color wheel is at fault if the sounds goes away right when the lamp shuts off. Look at the back of the set and watch for the lamp to shut down. The color wheel is not a consumer replaceable item.
Aug 15, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp keeps shutting off
Could be several things but the most common causes are:
1. Make sure that the lamp is working:
-make sure it lights up as viewed through the lamp access panel or the back of the set and stays lit. New lamps for most units are available on eBay for less than 100.00 with free shipping.
or
2. That the lamp access door safety switch is properly held in place:
-make sure that the lamp access door is in place and that the screw is snug. The symptoms of a bad / broken or open switch is that the unit will light up and the fans will spin for about 15-20 seconds then the unit will power down.
Other notes: A general comment on cleaning the fans... that is only part of a heat problem or preventive maintenance. Make sure you also clean the heat syncs of any dust. These are the fin shaped items... some are black and others are silver... found near or behind the fans. Get yourself a one or two inch SOFT bristle paint brush and gently wipe the fins clean with the nozzle of a vacuum cleaner close to the area to **** up the dust. Clean fans won't do much good if these are coated with dust and most of them are after a few months of service.
I have two 50" units and I clean them every year in the spring... before the heat of the summer hits. Unlike other TV designs, DLP's move a LOT of air so this is important.
Aug 14, 2009 | Samsung DLP HL-P5663W 56" TV
No picture on my new 46 inch samsung LCD
Hi...there,
It's seems your backlight lamp is burnt out... if you are still under warranty... call the mfg. up and get a replacement lamp.
Nov 29, 2008 | Samsung SyncMaster 460P (Silber) (Silver)...
Trying to replace lamp fan
First let make sure it's the Lamp fan. What many people think is the fan, And by the way there are three fans in this model, What sound like a fan is in fact a color wheel. So listen to the set as it starts up, these Samsungs make certain sounds when they start. First after you hit the power button you get the "Samsung Tones" from the speakers, second ALL the Fans start 1 to 2 seconds later the color wheel starts then stabilizes, third you may here the lamp fire. So if the sound takes two to three seconds after you turn the set on it's the color wheel BP96-00250A Now when it shuts down its like this First the shutdown "Samsung Tones" then watching from the back after a few seconds the lamp will shut off, then the color wheel stops but all the other fans remain on for about 2 minutes. I've worked on thousands of these and in only one or two was the problem a fan. but on the other hand I have enoghf bad color wheels I was able to make a pertty inpressive Christmas decoration
Feb 05, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Over heating
fan filter is probably plugged with dust, fan blades are also probably covered, unit will have to be taken apart and cleaned, lamp is overheating, probably a good idea to replace that lamp or at least order a new one and keep it for when it does finally die out, good luck with it, hope this helps
Nov 29, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
That certainoy sounds like the color wheel assembly inside of the light engine is bad. The light engine is located here http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00674A&search%5Fmodel=HLP4663W Good Luck
Aug 04, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
580 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
