Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Setup won't go through - error
I am trying to setup my new D-Link DSL-604T Modem/Router. I connect everything correctly as per the setup wizard - ADSL, WLAN, LAN port 1 lights all on. it then tests connectivity and gives an error telling me to check connections. Best regards, Kevin Flatt kevinflatt52@hotmail.com
  • kevinflatt52 May 31, 2009
    Thanks for the help. I have it working now. Disconnected old modem, left new connected and restarted. Went through fine.
    Problem Solver:
  • 7 Answers
I had a similar problem, and how I fixed it, was I made sure the connection was working, so the pc end had right details, and then I turned it off, and then put in router, and when it started back up, it started up and connected straight away.
Posted on May 31, 2009
  • w0lfm4n Jun 01, 2009
    No problems at all. Glad to help :)
Is this product compatable with vista? I have had this unit for about 6 years and has been in a closet. Changed my internet service and had this old router. It looks like I have it connected properly, but...
Routers are usually not OS dependable. Which means, yes it is. It is compatible. You need to go inside configuration and make sure your router is picking up IP address from your ISP. This is how to do it:
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down
your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the
WAN port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your
computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router
to boot.
7. Turn on your computer.
8. Verify the link lights on the router. The power light, WAN light, and the LAN light (the port that your computer is
plugged into) should be lit. If not, make sure your computer, modem, and router are powered on and verify the cable
connections are correct.
Now to configure router, do this:
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1). (no parenthesis)
Enter the user name (admin) and your password. Leave the password blank by default.
You may run the setup wizard to quickly setup your router. Click Setup Wizard to launch the wizard.
Click Launch Internet Connection Setup Wizard to begin.
Click Next to continue.
Create a new password and then click Next to continue.
Select your time zone from the drop-down menu and then click Next to continue.
Select the type of Internet connection you use and then click Next to continue.
Your connection is probably Dynamic, meaning your ISP is giving you IP address automatically and it changes. So, choose dynamic, and leave host name, mac address and everything else blank. Save it.
That should do it. You can also proceed to setup your wireless. Make sure you secure it also.
If any questions, let me know!
Aug 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Tip
How to setup the D-Link Dir-615 Wireless Router on the Internet 1. You will need...
1. You will need to connect your Cable or DSL modem to the Internet port on your router.
2. Connect your computer to any of the 4 LAN ports
3. Next you will want to insert the "Quick Router Setup Wizard CD" in to your CD-ROM drive. This will take you through the automated steps of setting up your router to work with your modem. Note if you have a DSL modem that uses a PPPoE connection software program you will want to uninstall it from the computer before you continue. Also you will need make sure you know the user name and password because you will need to enter it as a part of the setup for the router.
4. When the setup wizard opens you will want to click on "Install Router" in the upper left hand corner.
5. Click on the option for "Setup Wizard" to use the setup wizard.
6. Click "Launch Internet Connection Setup Wizard" to start to setup your LAN settings
7. Click "Next" to continue.
8. At this point you will be asked to create a new password. After you entered a new password click "Next".
Note it is important to setup a password at this point especially if you plan to setup a wireless network so no one will be able to gain access to your router settings.
9. Click on the drop down menu to select your time zone and click "Next"
10. You will need to select the type on Internet connection you have and click "Next"
11. Here are the different step you need to go through depending on the option you selected above.
DHCP
- If you selected DHCP then you might need to enter the MAC address of the computer that was last connected directly to your modem. If this is the computer you are currently connected to then just click on the "Clone Your PC's MAC Address and then click "Next"
Note you may need to enter a host name if this is required of your ISP.
PPPoE
- This is where you will need to enter your PPPoE user name and password.
Note as a reminder if you have not uninstalled the PPPoE software from your computer because it is not needed any more.
PPTP
- This is where you will need to enter your PPTP user name and password.
L2TP
- This is where you will need to enter your L2TP user name and password.
Static
- You will need to enter the network settings provided by your ISP
After entering the required information click "Next"
12. Click on "Connect" to save your settings. At this point your router should be rebooting. After it is done rebooting then click "Continue". Next you will need to wait 1 to 2 minutes while the router connects to the Internet.
Now you should be connected to the Internet. If you are not connected you may need to review you settings. Also you may try unplugging the power from your modem and the router. Then next plug the modem back in and let it run for about 30 second and then plug the router back in. If you still have trouble you may want to contact your ISP to make sure you have your settings right.
on Apr 26, 2010 | D-Link DIR-615 Wireless Router
How tinstall modeldir-615
Thank you for posting your question.
To setup this wireless router on your network follow these instructions:
Step 1. Plug in your D-link router to the wall outlet to power on.
Step 2. Connect the ethernet cable on your DSL or Cable modem to the WAN PORT on the D-link router
Step 3. Power on your DSL or Cable modem
Step 4. Connect an Ethernet cable from your computer to LAN Port 1 on the D-link router (if you have a wireless card on your computer, you may be able to connect to the router without using the Ethernet cable)
Step 5. Open Internet Explorer and type 192.168.0.1 then press Enter
Step 6. You should be prompted for a username and password, type admin for the username and leave the password blank, hit OK
Step 7. You will be brought to the Home Screen
Step 8. Click the Run Wizard button
Step 9. You will then input information regarding a new password, your time zone.
Step 10. After that the Wizard will try to detect what type of internet connection you have with your Service Provider
Step 11. If it cannot auto detect, you will be asked to select a type of connection
Step 12. If you have a DSL modem, you will select PPPoE, if you have a cable modem, you will select Dynamic IP Address
Step 13. If you selected PPPoE you will have to enter the username and password that your ISP has given to you for your connection.
Step 14. You will then be taken to the Wireless Lan connection screen, you can change the SSID or leave it default. Also leave the Channel at 6
Step 15. You are then brought to the Encryption Screen. To enable encryption, select Enabled
Step 16. Select your WEP encryption 64-bit or 128-bit
Step 17. Enter the Hex key (up to 10 characters)
Step 18. You setup is complete, you will be asked to retart the router through the Wizard, click restart
Be sure to rate/vot
Apr 27, 2010 | D-Link DI 514 Wireless Router (DI-514)
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
Dlink setup wizard problem
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 16, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
The modem's been changed and cannot locate the CD to the driver to connect to the internet. The model is DSL-G604T/AU V.A3.
Hi! your dlink dsl-604T is adsl router modem, you can access the setup page of your modem router by connecting your computer directly to the port1 of the modem router and the cable from your isp should be connected to the WAN port. u need to pull up the browser and type in at the url:192.168.1.1 and it will ask the username and password, by default the username is admin and the password is 1234 or leave it blank, but i suggest before u do this steps. u need to reset your modem/router. there is a reset button on the back of the router and press it for 20secs and then unplug and replug it after 10secs. after that u can pull up the setup page of the router.. to check the default gateway of the router, right click the network icon on the lower right of the task bar and select status and it will show the ip address, subnet and default gateway..
u need to know what internet settings u have with your internet provider, bcoz once u access the setup wizard it will ask u the type like auto-dhcp, pppoe, static etc.. if your isp gives u a username and pass to connect to internet u have to select pppoe or if u are given a static ip address setting u need to select static ip... just follow the setup wizard..
Aug 17, 2009 | D-Link DSL-G604T Wireless Router
D-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
Orange blink of death!!!
Hello houng_lee,
I have the exact same modem, if the modem/router light is blinking, that indicates a problem with the modem. You indicate that you have internet connectivety, so you should have modem light solid blue. When you look at the Wireless light it's probably off. Which means that at this point you have internet connectivety, you should put the cd in and run through the wireless connection wizard on the CD. It will check to see 1) if you have internet connection, 2) the type of connection you have (comcast) 3) if you have any wireless devices to be hooked up. 4) That all connections are working properly.
If you have a laptop that you want to connect to the wireless router, have it next to the router, so once you've finished setting up your Wireless security and issing a WEP number for local access, you can test your setting immediately with the Laptop. I always suggest that you create a WEP number for securty reason, If you perfer not to create a WEP number, and leave it as an open access (which is fine, and easier to setup) make sure that you shut off broadcasting, So your neigborhood doesn't jump online once they see an open access router.
If you've tried these steps let me know what problems your getting during the wizard setup. It will tell you if everything is setup correctly, or their is an error. Right now, I think the problem is your setup, and it's not communicating correctly. But, the wizard will tell you that as well.
Let me know,
Good Luck
Mark
Feb 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot Connect to the Internet Using a New D-Link DSL-2640B
1. Make sure you have the latest firmware
2. Restore to factory settings first. This helped me with stacked ppp session.
3. Setup your connection according to ISP
4. If you have problem, install Router Commander from www.routercommander.com
5. Setup router to send syslog to your PC
6. Check syslog messages about the clue what's going on
Dec 17, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
141 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
