Question about Philips Televison & Video
No longer seems to get any ppower to turn on it was working before it went into the moving van
It was working when it was loaded into the moving van but no longer has any sign of getting power now. no electricity.
    Scholar:
  • 150 Answers
Hi, would help immensely if we knew who built the set and the model number. obviously the move has either un-plugged a connector somewhere inside the set or the move has broken a few solder joints, remove the back cover and with the set un-plugged check for a good connection on all the cables, you`ll have to take boards out to check solder, gl, video-tek
Posted on Jun 05, 2009
In the highway the tranny just went, a grinding noise was heared from back of the tranny every time that put it in gear. after cooldown I was to able to move forward 50 mtrs, then, went again. After a...
You need to have it rebuilt
I would suggest you don't do that,having once
owned a trans repair shop
I would get rid of it & stay away from all van
type vehicles,especially caravans & all ford vans
Jul 17, 2011 | 1999 Dodge Grand Caravan
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
Transmission
Check your universal joint...might be broken.
Jun 01, 2009 | 2003 Ford Windstar
Liftgate on van not working at all
There are 2 support shocks that support the lift gate. You need to replace them. One or both of them are no longer supporting the door. Your local auto parts store will have them in stock. Compare prices with competitive stores, prices vary depending on where you purchase them from. It't really easy to replace them.
Apr 06, 2009 | 2005 Mercury Monterey
2002 Windstar wont go into gear
These are common for the pump shaft splines stripping in the torque converter. The transmission will need to be removed to fix it. Before you condemn the trans, does the speedo move and the van doesn't or do you hear any grinding when you put it back into park? Or can you push the van in park (Broken CV shafts)?
Mar 28, 2009 | 2002 Ford Windstar Cargo
Sterring column feels like its stripped
The neutral sensor went out thats why it wouldn't turn on and I accidently broke the sterring coulumn so I went to the junkyard and found the same van and took off that sterring column. Now its on my van and its running better
Jan 16, 2009 | 1990 Plymouth Voyager
Van suddenly shut off one day and will not start
check the timing belt,remove the oil cap.....if you, can look at the valve train to see if it's moving when some one turns the key.........if it's not possible to see through the oil cap opening you may have to remove the valve cover if the valve train isn't moving the timing belt is probably broken.
Keep Me Posted! I'll try to help more if that's not the problem.
Thanks for choosing FIX YA!
Jan 03, 2009 | 2000 Plymouth Grand Voyager
2000 plymouth voyager problem with ignition switch?
Your problem is caused by the little pins that the key moves to unlock the cylinder, they are sticking, go to a parts store and buy some graphite lock lubricant, if that does not help you will have to replace the lock cylinder before it jams and strands you somewhere.
Oct 11, 2008 | 2000 Chrysler Grand Voyager
Top Loading whirlpool washing machine.
Could be the top lid switch. If the timer has stopped moving (you can no longer hear it clicking along) good chance that's what it is. When it has stopped try pushing hard down on the top of the lid AND/OR put a piece of plastic (or something ) into the lid latch switch... See if it continues on with the wash cycle...
Mine just went bad this week. Bought the part for $25...
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
TRANSMISSION PROBLEMS
After a full days work I went home park my Van, got up the next morning started the van put it reverse would not move so I put in drive the same thing happen would not move please help.
Jul 04, 2008 | 2005 Mercury Monterey
Televison & Video Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
