Washing machine has a water leak cannot find any manuals to find problem hopefully someone may have an idea
ASHING MACHINE HAS A WATER LEAK
  • scottleann May 31, 2009
    hi the make and model no are LG fuzzy logic WF-T753A any ideas or help would be great thanks
    hi checked the back of washing machine it says model# WF-T753A don't know if is will help
    President:
  • 1,136 Answers
HI, Could I get a model # so I can assist you better? I can see exactly what model you have and give you ideas on what it might be.
Thanks
Vic
Posted on May 31, 2009
  • Victor
    Victor May 31, 2009
    I am sorry but the # isn't coming up. Is that the whole number found on the label of the washer?
    If you tip the washer back against the wall and look underneath, can you see the motor, pump, & transmission?
  • Victor
    Victor May 31, 2009
    I.m sorry, I can not look these up. I thought LG was made by General Electric
    You might have to repost your question so another tech can help you.
    I am sorry for taking up your time
    Vic
LG WF-T652A I have a leak when the machine is on. I have checked both the outlet pipe and the pump , neither are leaking or show signs of water. Is there an overflow from the bowl which may be the s
when the cover is off turn the machine on and trace the leak if you can it could be from a faulty valve. also see where the leak is on the ground so you can get a idea where the leak is.
Jan 09, 2015 | LG Washing Machines
Possible water leak
you probably need to call a technician if you have water leaking onto electrical parts. if you're game, unplug water, unplug power. look for your leak and plug it, problem solved. if your washe has been getting louder recently, this leak could be coming from the seal inside the machine, and you will need someone to do this job for you, as it is quite involved.
Nov 09, 2013 | Miele Washing Machines
LG Intellowasher 7kg wd-8015c leak
Most of the time it is the door seal, open the door and check all the way round. check the sump hose and pump, sometimes it can leak from the soap draw hose to the outer tub, but not in your case I think. In most cases this can be fixed easy and is the door seal. to find out if it is coming from the front or the back, just place some news paper on the floor under the machine and take a look to see if it is the front or the back. a door seal is about 15/25 pounds retail
Oct 24, 2012 | Washing Machines
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
It has just come up with the Error code...AE...which in the manual says Water leak, but there is no water..and now the machine will not work at all....
You need to open the machine and have it inspected for a water leak.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | Washing Machines
Can you you tell me why there is a flashing red light on the coffee machine
Descaling light:
• on and fl ashing: signals the need to perform a descaling cycle
Machine ready light:
• permanently on: signals that the machine is ready for use.
• on and fl ashing: signals that the machine is warming up.
Alarm light:
• permanently on : signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full (in this case, also empty
the coffee grounds drawer in order to prevent failures).
• on and fl ashing slowly: signals that the brew group is not inserted, the
dregdrawer is not inserted the coffee bean hopper lid is not on, the service
door is open or the steam/hot water knob is not correctly turned to the
desired position.
• on and quickly fl ashing: signals the need to prime the water circuit.
Jan 13, 2011 | Saeco Odea Go
Water leaks out at the bottom of the front, just below the door
If you can remove top from machine and then fill you may be able to see leak. Some times although it appears to be leaking below the door this is not always so as the water will build up inside the casing and give you the idea that the leak is there. Sometimes to find a leak it is nessessary to put washing into machine, with the back and top off to find the exact place, as a leak is not always easy to find. If you need to go to this stage then take extra care that you do not touch any parts, as I have seen people forget that electricity is not very friendly, also moving parts will start up at any time. Good luck I hope this information will help you.
Feb 12, 2010 | Washing Machines
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Leaking water from the front of machine,
Hi
The water level in a front loader should always be below the door line so consequently it should not be possible for water to leak out the door unless there is a problem with the actual door seal itself.
However if you are using too much, or incorrect type of detergent, the washer may be producing too much suds. Too much suds can cause door to leak.
Other causes of a leak which appears to be coming from the front but is on fact coming from elsewhere: Check the water inlet hoses. Check the drain hose. Check the standpipe (upright drain pipe used instead of a sink), or the wash sink connections. These will often be the actual source of a leak. When they leak the water can roll under the washing machine and appear at the front.
Also check this link for a good description of how to troubleshoot leaks happening at various stages during the cycle.
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itleaks
Hope this helps. Thanks for using FixYa.
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from washer
you most likely have a pump leaking post your email so i can send you the manual
Nov 03, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
