Question about Dell 926 All-In-One InkJet Printer
MODE COPY on screen of Dell 926 printer,will not print
My Dell 926 has the words MODE COPY on screen, I am un able to print anything please help me!!!
IrishDruid
  • 2712 Answers
SOURCE: Dell Photo 926 printer scanning problems
Go HERE and select your OS and download the latest version of the driver. Then uninstall the older version on your PC, reboot, and install this version. Dont plug in the printer to your PC until instructed to do so in the installer.
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 30, 2008
yooperbud
  • 8637 Answers
SOURCE: Can't get Lexmark X5410 to print. Printer is on "Copy Mode"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Vivektj
  • 55 Answers
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Posted on Mar 02, 2009
john_yap
  • 51 Answers
SOURCE: printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Posted on Oct 19, 2009
Rossiman46
  • 50 Answers
SOURCE: How to install ink into printer 926 dell
There should be a button on your printer, you would need to press it in untill the carriage moves over into the install new cartridge position, you will know when it happens you should hear it.
Take out old cartridge 7 install a new one, normaly when you shut the lid down the printer will automaticaly do a head clean better known as priming the cartridge, you should then be ready to print.
Posted on Nov 06, 2009
Testimonial: "Didn't find any button to push"
What mode does 926 Printer must be in to print?
For printing from the computer, I beleive it is 'copy' mode.
Mar 30, 2014 | Dell 926 All-In-One InkJet Printer
My Dell AIO 926 printer remains in copy mode. How do I change it to print?
If you printer not show normal mode then go to run and type printer spool. If not solved then go to control panel and Administrative Tools and click services option and search print spooler stop and start. I hope solved you problem. If not solved then one time printer off and some time wait and restart.
If more problem face then contact good printer support technician.
TechSupportPrinter
Thanks.
Jan 14, 2014 | Dell 924 All-in-One InkJet Printer
Why does my Dell 926 require access to the internet before it will print anything? I have to grant 4 different dell programs firewall clearance or it refuses to print.
It does not!
It probably wants to update the manufacturers website with registration or look for updates.
You can disable this within the support program to make sure these options are UN-ticked.
Mar 07, 2010 | Dell 926 All-In-One InkJet Printer
I can't print anything my printer shows (cover
Check the connection of the printer. the sensor is not functioning.
Aug 20, 2009 | Dell 926 All-In-One InkJet Printer
Unable to print on printer Dell 926 -test page prints ok
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 23, 2009 | Dell 926 All-In-One InkJet Printer
Printer locked on printing
Try changing your firewall, it worked for me. I got my 926 a year ago with my Dell and had no problems until I replaced my expired Norton w/a freebe that was very aggessive then the problems started. Would not comunicate sometiimes and when it did it printed once than froze. Would not delete printed doc or print the next. I remembered that McAfee made my old Emachine freeze or crash. Put Norton back on and no more problems. Hope this helps you.
Jan 29, 2009 | Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
238 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
Jerry Umali
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
