Question about Toshiba 30HF66 30" TV
Black screen I just bought a Toshiba 30HF66 30" 1080i Widescreen Digital Direct View TV and when I turn it on I get sound, the power light is red and I get no picture at all. Any way I can fix this?
  • 790 Answers
Re: Black screen
you have good sounds but no picture. ok maybe you have defective parts like fusible resistor that is connected at the heater circuit.. the picture tube needs to heat the 3 grids (RED GREEN BLUE GRIDS) if no power in heater you got no picture good sound. sir i think you need a qualified technician to help you resolved your problem.. this is very easy to fixed for a technician and this is not expensive... thanks!!!
Posted on Nov 05, 2007
  • 151 Answers
Re: Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Posted on Oct 24, 2007
0 characters
3 Points
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
The TV picture is set on widescreen (black bars on top and bottom of program). I want it set back to standard view (w/o bars)
Tries tv unplug,replug it back like about an hour later.All ur tv setting will be resetting,tv should work in full screen again.Unplug,replug the cable box back like an hour too,if this tv it hook up to a cable box.
Jun 05, 2011 | Toshiba 32AF62 32" TV
Toshiba 36HF71 has sound but no picture
Same problem with mine. Relays click, sound, no picture and a flashing power LED. I finally found a schematic online. I went through the high voltage circuits and found the power transistor 2SC5570 was shorted out. There is also a pico fuse in that area but my was not open. I replaced the transistor and prayed the flyback transformer was not shorted. It wasn't, I'm watching my old 36" right now. Not a bad fix (17.00) bucks. Wonder what a service tech would have charged ;)
Jan 02, 2009 | Toshiba 36HF71 36" TV
Tv won't turn on or respond
the power supply is faulty, check the following for lekages
power transistor
rectifier diodes
fusable resistors
also griver transistors
Nov 25, 2008 | Toshiba 35A44 35" TV
Toshiba 32AF43 problems
bright red with lines left to right? would be shorted crt. shutting off would be normal due to high beam current.
Nov 09, 2008 | Toshiba 32AF43 32" TV
Philips 32pw9527/05 tv does not start
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
Jul 31, 2008 | Standard (CRT) Televisions
Toshiba tv mod tp55h60
Is this set a tp55 projection or a 36a40 direct view? If projection, these sets are bad with convergence problem. Meaning the color goes haywire, red, green blue are all misalign. If this was not what you experienced then it also could be a sound problem or vertical. Either way if you press power and will not come on it's tell you that there is a problem that needs to be address.
Sep 16, 2007 | Toshiba 36A40 36" TV
Tv shuts off
My TV turns on and off constantly, it wont stay on for more than 2 secs. Please help.
Aug 25, 2007 | Toshiba CN36V51 TV
Toshiba 30HF66 30" TV Logo
226 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
