Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Water wont quit running
I have a frigidair ulttraquiet I was working fine then one day it started filling with water and wouldn't quit i went every were can turn the dial off and it will keep running what should i do?
    President:
  • 1,136 Answers
HI, if you are getting water with the power to the d/w off, you will need to change the inlet valve. the valve is locate uner the d/w in the front left corner.
You should have a shot off valve under the sink or in the basement (if applies).
Sound like the valve has gone bad and is stuck open.
I hope this helps you. If I can assist you further with part # or anything else, please leet me know.
Thanks
Vic
Posted on May 31, 2009
    Brigadier General:
  • 8,619 Answers
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Just bought a beko washer dryer wdr7543121w. The day I got it I did three washes then dried the clothes everything was fine. The next day went to do a wash and it wouldn’t work it keeps coming up with the...
call the manufacturer and ask about warranty service . do not mess with it until they check it, WARRANTY will be voided if you do ... perhaps the pipes have froze .
Jan 01, 2018 | Beko Washing Machines
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Been setting in storage a year when all hooked up it starts up just fine then quits and sets there with the timer running but wont wash or spin or nothing wont fill with water
When you mention that it starts up fine. Do you mean that the machine initially takes in water, but then nothing after that. Or does it simply power on, but no water comes into the machine.
If no water comes in initially, then it is most likely your inlet valve.
If water comes in but no motor action, then it could be a raft of things. Disconnect the power source. Open the top hatch and the back panel. Make sure the drive belt has not come off during transport. Also check to see if no wiring connection has come loose. NOTE: Make sure the machine is off and disconnected from the power plug.
If you can't spot anything loose then it is best to get a service technician to diagnose the problem.
Ash
Oct 21, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer wont fill up, keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer fills up fine but doesn't start to wash...
if it doesn't agitate, spin, or even drain, then you most likely have a belt that is off. Of course, now that you have a washer full of water, it is going to be diffficult to tilt back and change the belt, so you might want to get a shop vac and **** the water out through the drain hose first.
With most of the water out, you should be able to tilt the machine back and see what went wrong. I believe on Frigidares the belt is underneath.
Mar 08, 2009 | Frigidaire GLWS1233A Top Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Nov 21, 2008 | Maytag PAV2300 Top Load Washer
Washer does not fill at all
Have you checked the filter just inside the water hoses. You just turn off the water and unfastenent he hoses from the machine and you will find a little filter. It may be clogged with lint, sand, etc.
Jul 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
187 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
