AC blower runs but compressor will not.
Carrier air conditioner FA4ANF030 Unit stopped several days ago and after about an hour I turned it back on and it worked. It quit again. The blower runs but the compressor will not. Drain is OK and fuse is not blown.
  • gator42_2001 May 11, 2010
    does it cool when it comes on or just blows air? is your filter clean,evap coil in air handler clean? is your capacitor in condensor (outside unit) is it leaking or maybe it is weak several possibilities but not enuff info....
  • Complectric May 11, 2010
    If you try to restart it again after an hour of being idle, does it start? And how long does it run before stopping? If you repeat the process, does it consistently run ABOUT the same time before stopping?
    Problem Solver:
  • 7 Answers
It could be the CONTACTOR. It could be dirty and when the system calls to run, the contactor won't make contact and complete the circuit. Worse case scenario, compressor is siezed up. If you hear a clicking noise at the condensing unit where the compressor is located, that could be the overload protector clicking and breaking the circuit if the compressor is seized up. Good luck. I hope it is a contactor or a capacitor.
Posted on May 31, 2009
Carrier 38 leo 30320 ac unit....when the compressor shuts off the fan keeps running. a rap on the control panel shuts it off. I when changed the contactor the inside unit stopped working so I put the
Hello, if the indoor blower runs nonstop a relay in the intergrated control board faulty and the whole board must be replaced, you can get tap the board to stop the blower but eventually the board will need to be replaced. If the contactor is clicking that means it is receivingpower from the indoor unit
Jun 16, 2012 | Carrier Heating & Cooling
MY AC WORKS FOR FOUR HOURS PER DAY AND BARELY COOLS DOWN THE HOUSE, NOT MUCH AIR COMING UP TO THE UPSTAIRS OF THE HOUSE. AFTER 4 HOURS, THE OUTSIDE UNIT SHUTS UP AND NOT MORE COOL AIR COMES IN. BEFORE THIS...
I am not understanding exactly what is happening with your unit. You say it only runs for 4 hours a day and then say that after 4 hours the outside unit shut off. But you don't describe the condition of the outside unit! Is there ice on your outside unit after it runs for four hours or is it so hot that the housing would fry an egg? Since it works for four hours and then stops working, I would guess that ice forms on the condenser grill which tells the thermostat that your air is much colder than it actually is. Then it takes time for the ice to melt off again. Am I close? If so this condition is usually caused by your unit being low on freon making everything work harder. But it could also mean that you have a leak in the system somewhere. But it shouldn't be much of a leak or it wouldn't run for the 4 hours.
I would recommend you charge it to the correct level and then check for leaks.
Aug 03, 2011 | Carrier 38CKC060 Air Conditioner
Air conditioner compressor seems to quit after 1 to 2 hours driving-blower stll runs, but cold air stops green compressor lite is still on, but no cold air-turn off ac for 20 to 30 minutus, comes back on...
Sounds like the air gap on the compressor clutch is to wide, when the compressor turns off to recycle the electromagnet on the clutch is not strong enough to pull the air gap and lock up compressor. The air gap is adjustable and should be checked.
Jul 26, 2017 | 1994 Toyota Camry
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Carrier central ac model 38EN036300
If you have an electronic thermostat, they can short out, leaving the compressor running. Also, the big relay that runs the compressor can get its contacts welded together. See if the contacts are stuck closed.
Jul 27, 2008 | Carrier 38CKC036 Air Conditioner
Ac turning on and off
How did they check the freon in the home? You can feel the front(evaporator coil)coil on all four sides. Are you sure the motor is running fast enough? If the four corners do not feel cold in about 5 minutes or so, there is a compressor problem, Capillary tube blockage, moisture in the system or you are low of freon. Good Luck
Jun 15, 2007 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
498 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
