Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Need a service manual to take appart back panel of fridge
I have a GE Profile Refrige model # PSC23shmb. There is a fan just below the Ice make motor behind the back wall panel of the freezer section that is making a grinding noise as if the blades are hitting the cover. when I press on the panel, the noise can stop or get worse depending on how I put pressure on it. I need the service manual to tell me how to take off the back panel to look inside. Thanks.
  • Victor
    Victor May 11, 2010
    Hi, I don't have a manual but I can give you an idea. UNPLUG the refrigerator. There should be screws holding the rear panel up. remove the scres and the panel should release. Some models you will need to remove the ice maker also.
    If this doesn't help you, maybe someone else will have a service manual.
    Vic
    Novelist:
  • 103 Answers
Ge profile not defrosting
is the fan motor running? there an obstruction to air circulation. how old is unit? is it clean under fridge? if older than ten years, could be losing refridgerant. May have to have it serviced.
Dec 10, 2013 | Refrigerators
PSS26MSRSS-PROFILE-EVAP. FAN RUBBING,NEED TO ADJUST
I don't believe you can reach the evaporator fan without removal of the ice maker. Unplug the refrigerator while working on ice maker and fan motor. It is easy to remove the rear panel. Questions?...Sea Breeze
PSS26MSRSS Service Manual
Feb 12, 2013 | GE Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Aug 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
May 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Jan 01, 2010 | GE Refrigerators
GE Profile making knocking noises at different times
I have the GE profile Refrigerator with ice maker in the refrigerator compartment. Mine was knocking loudly for long periods of time, so I finally removed the icemaker by removing the side panel in the icemaker compartment held with 1 phillips head screw, disconnecting the electrical plug (unclip), pulling the tab of the icemaker down (on top) and sliding it toward the door, thus removing it. There was ice frozen in the motor compartment that was the problem. I let it thaw out and re-installed. All was OK after that..
Jun 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Nov 18, 2008 | Refrigerators
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
