Question about Jensen CD400M CD Player
FM Reception with Jensen MSR3007
The FM reception was great for about three months with my new Jensen MSR3007. Then suddenly, the FM reception/sound became horribly static, with pops, crackles and the sound will fade in and out. I have replaced the antenna to a power Jensen antenna and it still makes the same static, pop and the sound fades in and out. All the other components, CD, iPod and auxillary input work fine. Any suggestions as to what Is wrong with my FM reception? thanks for your help. I have similar problem. Howard, did you ever find a solution?
  • Jim Nov 11, 2013
    Update: Don't buy Jensen. The J stands for junk. I replaced one of these models with 5 hours of playtime on it with a brand new one via warranty. I also had very limited play time, was removed from boat every winter. After it failed with same symptoms, I've opened it up and the workmanship inside is TERRIBLE. Lots of cold solder joints, especially the very large ones but more concerning is the jumper wire soldered to a male pin on the board. that same male pin is part of a plug connection. I'm ok with properly added fixes like an additional soldered component or jumper but not attached to this point. Bite the bullet, trash you radio and wired remote and replace it with another brand. You'll be happier in the long run and this will eliminate your frustration with Jensen Junk.
  • Anonymous Mar 31, 2014
    Jensen 6223. no FM reception, just static. Get a few AM stations. I tried a new antenna, still nothing. car came from about 3000 miles away, is there some sort of adjustment to be made?
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
Posted on Jun 15, 2009
Hello Jensen MRS 3007 Victims!!!
My my boat had lost reception.
I bought a new one and installed it, fixed?
One rough day of boating and the new radio lost reception!
Jensen MRS 3007 has internal antenna problems.
Anyone ever successfully fix this problem?
Thanks for any info!
I might never buy a Jensen product again!
Posted on Jul 12, 2014
I also have the same problem. I solders a new antenna lead onto the printed curcuit board. now it plays good for 30 seconds then goes back to the static, crackling and popping. Does anyone know how to fix? Hate to buy a new one because I also have a remote for the Flybridge installed
Posted on Sep 20, 2012
I had the same problem we should form a class of dissatisfied customers and require some sort of payment from jensen
Posted on Jul 23, 2012
  • Jim Nov 11, 2013
I have the same problem, it's a cheap worthless piece of ....
Mine will not play a cd burned as mp3 format.
Posted on Feb 04, 2010
  • ccruser1 Sep 21, 2011
    I have exactly the same problem. It appears the issue is in the antenna lead coming out of the back of the radio. The only true fix is to pull radio apart and solder new antenna lead to board. i try'd cutting and splicing new lead to old lead 3" from soldered connections with no success. The antenna lead is a very small diameter wire and I think is prone to this problem.
    Solution: Buy new radio.
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory ┬╗ FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
Apr 11, 2012 | 2008 Toyota Avalon
I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
Flavio/Brazil
Jul 13, 2010 | Sony Audio Players & Recorders
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
No FM reception on factory 1996 dodge grand caravan radio
replace the attenna if that does not work the radio is the problem
Jul 16, 2009 | 1995 Dodge Caravan
Reception on fm is not very good
Unfortunately there are only two real ways the reception could be "bad".
Either your MP3 player is a lemon itself (meaning a single defective product, in which case you can return it, if you bought it recently!)....OR, the more likely answer is that MP3 players with FM tuners generally don't have great reception.
I have run into one MP3 player that has pretty good reception, and that is the Zune. It lets you set presets and such as well. Hope that helps!
Jun 25, 2009 | Sony NWZB133F MP3 Player
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
FM RADIO DONT WORK..MODERATE AM
hi sounds like a torn ant wire or bad ant change the ANT with all the length wire till the reciver make sure a good connection in the reciver good luck
Mar 26, 2006 | Jensen 200W AM/FM/CD Car Receiver - CD4610
No FM Reception
So what is the question? send it back ASAP. As far as i know there are a lot of problems with Jensen CDs...
Nov 26, 2005 | Jensen JCR-280 CD Player
Jensen CD400M CD Player Logo
1,643 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
