Question about HP Pavilion dv6000z Notebook
There is no sound comes from my computer,speakers are good,there is no mute.
I think my speaker has no problem ,but there is no sound completely coming from my computer.i changed the speaker ,but the same problem still there.i checked that there is no mute on my speaker .what should i do?
  • HP Master
  • 2,404 Answers
Just to be sure, boot up your laptop and go into the BIOS. I think by pressing F10 it should take you into the BIOS.
Reset the BIOS to factory default in there, save changes and exit.
After it gets into windows, see if you have sound, if not then reinstall your sound drivers for the laptop.
If after that you still don't have sound then that means there is no power coming out of the power connector for the speaker wires and that means the motherboard would have to be replaced.
Posted on May 31, 2009
How to Resolve No Sound on Windows Computer?
Ensure that you aren't muted. The Windows Sound icon is small, and it can be tough to see if you are muted or not. Click the Sound icon in the System Tray and then click the Speaker button in the pop-up that appears to toggle the mute
  • If you don't have a sound icon, then your sound drivers are likely not installed correctly.
Inspect the speaker or headphone connection to the computer. A bad connection is one of the most common causes of no sound, and is also one of the easiest to fix. Make sure that your speakers or headphones are plugged in completely, and that the cables and connectors aren't damaged.
Ensure that your speakers are connected to the right port. Make sure that your speakers are plugged into the correct port on the back of your computer. The green port is most commonly used for external speakers, while the orange and black ports are used for surround sound systems and subwoofers. The pink port is for microphones.
Make sure your speakers are powered and turned on. Many speakers require a power connection, and may need to be turned on in order to work. Check the volume controls on the speakers as well to make sure that they're turned up enough to hear.
Reconnect your HDMI cable. A common problem for HDMI users is that no sound comes out of the speakers that the HDMI cable is connected to. A simple fix for this is to unplug and then replug the HDMI cable, which should switch the default playback device to the HDMI device.
Oct 20, 2016 | Microsoft Computers & Internet
There is no sound coming out of speakers
Check to see if you have the speakers muted. There is or should be a small icon down in the right corner that looks like a speaker. double click on it and see if it is muted.
Feb 07, 2011 | Dell A215 Computer Speakers
Music is playing - everything is turned on - fixit says there is no problem - sound card is active - speakers worked yesterday - now nothing, no sound is coming out of speakers
you might have hit by accident a windows mute key or a mute on your speakers themselves or maybe the wire that plugs into your speakers or computer got disconnected accidentaly.
try going in your Control Panel and check what u have in the Sound tab, it might give you some clues if the problem is inside the box.
you can also go into Control panel and Device manager and see also the sound Tab in there see if also your card shows up there...
if u have also an onboard sound card and also a pci sound card those can get into conflict if both are active at the same time.
good luck!
Oct 22, 2010 | HP (ED808AA) 2 Speakers
I dont have any sound on my computer
If there is a speaker on the right handside of the taskbar (next to the date and time) the computer thinks there are no problems with the software driver and all is OK. If there is a red line across it then the sound is muted; the solution is to unmute it. If there is no speaker at all then the problem lies with a software driver. You need to install the software so the sound comes up. The software can be downloaded from your laptop manufacturers' website under support. Good luck.
Jul 15, 2010 | Computers & Internet
Not getting deteected
Speakers do not get detected, they only produce sound when you play any. Reboot the PC or laptop and on shutting down and startup Windows plays its own sound. That should come through these speakers. Now go to the Sound option by clicking open the Volume icon in the system tray and check and make sure that nothing is muted by Windows. And listen to your favorite music as these are good quality speakers.
Nov 19, 2009 | Altec Lansing AVS 200 Computer Speakers
No sound from speakers
Check to see if your computer settings arnt muting your speakers
Check to see to if the audio driver software isn't muting the speakers as well
Oct 17, 2008 | Logitech Z-2300 Computer Speakers
Sound not coming out of the speakers
Check your sound settings on your computer
Check to amke sure your speakers are muted by the computer
Check to see if the volume is down or muted on the program that is playing the music
Sep 04, 2008 | Manhattan 1100 Computer Speakers
Hello
Hi uptown109
happy Holidays
well, depending on what brand of sound card, (onboard sound) or external sound card, you have to prove if you get sound (green) connector with a headphones, then connect the green cord from speakers to the green connector on sound card, go to control panel then and test and up in the mixer all volumes, see if not mute .
good luck
Dec 22, 2007 | Sakar Adrenaline Computer Speakers
About computer speakers
1 st check u r speakers ..........are they o k or not..
i think ur speakers r shot or not working......
to check u r speakers u can use any other audio source like a walkman,other computer. etc....
if u find that ur speakers are ok them u should check u r volume controle on ur computer man.............is u r volume is mute...
if u problem still reman then follow these steps..
1.check u r all cable connection ....they should be properly attached
2.go to u r computrs controie panal..
3.select sound & audio device..
4.check  u r all audio driver r working properly or not....
5.if volume is mute...get off the mute..
i m 100% sure u r problem will be solved man..
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Audio Players & Recorders
HP Pavilion dv6000z Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
