Question about Samsung Televison & Video
Samsung model ct-5071xvc wont open
Tv wont open and the small red light bettween control panel and on/off button tilt ! help me plz
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Posted on Jan 15, 2008
experttv
  • 203 Answers
SOURCE: Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Posted on Sep 12, 2008
jingjao
  • 252 Answers
SOURCE: Panasonic CT-36HL43G five blinking lights
check the horizontal transistor
Posted on Sep 29, 2008
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
I have a Samsung Plasma TV (pn60f5300afxza) and when i try to open my TV there is nothing on the screen and the red light flashes. The screen doesn't open or nothing.
Samsung remotes sometimes have buttons up the top of their remotes to control other devices. I accidentally hit these sometimes and they change the controller to another (not connected). Ensure TV Button on top of controller is pressed before using remote to turn on tv.
Nov 07, 2016 | Samsung Cell Phones
Tv button wont work
Check whether the panel lock function is ON. If it is ON, make it OFF. Refer the user manual to your TV for more details.
Jul 04, 2016 | Toshiba CT-90255 Remote Control
Tv wont turn on red light just flashes green then back to red.
Can you take a look behind your tv and post your model number plz
Oct 16, 2014 | Televison & Video
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
Needs a code to key in a universal remote control to be use on samsung tv model CT 3312J
Hello
Three digit universal remote codes for samsung are:-
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
Four digit universal remote code for samsung are:-
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 19, 2011 | Samsung Televison & Video
My remote control is a model CT-90233. Several of
your remote is old and needs to be cleaned and rebuttoned(you can do this yourself) open up the battery panel and look for small screws to take of the case. you need to dust it out with compressed air. and reline the buttons. when you push down on the power button it probbaly is not making complete contact with the button, take a small thing and poke the power button without the buttons on. see if that works. if it turns on right away with direct pressure to the power switch then you just need to make sure your buttons are making complete contact. if that dont work then your circuit is screwed. you need a new remote or a new tv.
Feb 16, 2010 | Toshiba 32A30 32" TV
Samsung TV model CT 5029V - Lost remote control - AIR/CATV
do you have a menu button on the t.v. itself? if so gain access there
Nov 01, 2009 | Samsung TV Remote Control
I have a samsung tv model CT-5063V then i buy kenon universal remote control the problem is i dont know how to set so that i will function...plz help me.
dont you have the original remote ? I would purchase another one if you can find one online -- that way you dont lose any functions --- I can help you find one --- just give me that complete model number ?
Mar 02, 2009 | Samsung CXJ1352 13 in. TV/VCR Combo
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
67 people viewed this question
Henry  Thomas
Henry Thomas
