Question about Kenmore Refrigerators
I find the flat ice on the bottom shelf
I find the ice in the bottom shelf
    Novelist:
  • 103 Answers
Hi: Without any information on the style of the fridge I will assume this is a top freezer as the problem is common with these. Your defrost drain is plugged and the water has no where else to go. If this is in the freezer it means your ice maker is cracked or out of level. If you need more help please give me (us) more information on your ref. Model number and style. Good luck, Jeff
Posted on May 31, 2009
2 Suggested Answers
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
Ice in refrigerator
Usually a blocked drain at the rear just above the bottom shelf. Use a plastic drinking straw to clear the hole. Could just be condensation if you are in and out of the fridge a lot.
Aug 07, 2012 | Frigidaire FRT17B3A Top Freezer...
My freezer part of the refrigerator collecting ice in bottom shelf
Is it collection frost on the back and bottom shelf or is it ice on the very bottom of the fridge?
Aug 17, 2010 | Maytag Refrigerators
Ice maker does not make much ice - what could be the problem. overnight only about a quarter of the tray is full - Ice compartment is never full no matter how long it is between using the ice. What can...
You can boost ice production by cleaning the fins below. The better air circulation around the compressor the better performance you get. The water filter may need replacing. The water valve may need replacing. I have the same ice box as you and have not noticed a problem with the shelves. You can adjust shelf heights you know.
Apr 03, 2010 | Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Mar 21, 2008 | Refrigerators
Gas bottom shelf for Thermos Grill2Go ,Fire and Ice.
try this: http://www.thermos.com/contact.aspx
Mar 07, 2008 | Thermos Grill2Go Fire+Ice
Whirlpool refrigerator with top freezer either model GR2 or 9FHTXT will not keep get cold
Sounds like the defrost drain has become iced over or clogged. This is why the ice builds up.
Jan 14, 2008 | Refrigerators
Refrigerators Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
