Question about JVC KD-PDR30 Car CD/ MP3 Player
No AM reception for car radio...do get FM reception.
Just bought a brand new JVC KD-HDR50 car radio, with HD FM/AM, CD and iPOD capability--for my 1999 VW Passat. The FM reception is great, but I get no AM reception whatsoever. Is this usually an antenna problem? radio problem? Could somehting have been installed incorrectly? I got it installed by bestbuy. How can this be resolved? Many thanks!
I was having the same problem with a jvc kd hdr 30. I Installed it myself over a year ago and never wanted to deal with the issue. Finally, I decided to take a look at it today.
On my head unit, all wires were connected except one blue one with a tag that says "do not connect to power, for remote device or power antenna only." This unit is in a '97' MBZ E320 with no visible antenna; I think it is part of the windshield. In any case, between the wiring diagram in the manual and the harness that is part of my car, I was left with 2 blue wires to choose from, one with a white stripe and one with a gray stripe. After testing both for power or ground, I determined neither had power with key on or off. Both had high resistance ground when compared to the chassis ground. In other words, I measured between chassis and these wires. First, I took a wire and connected it to the chassis ground and connected the other end to the blue wire coming from the unit while tuned to a local am station. This simply killed all reception am or fm but did not harm the unit. Next, I connected the blue wire with gray stripe of the car harness to the blue wire of the unit and again this killed all reception. Then I connected the blue wire with white stripe of car harness to the blue wire of unit and presto magic I had great am reception.
I am guessing that this blue wire with white stripe must be part of the antenna itself or perhaps is a connection that increases antenna power. Maybe 'power antenna' on tag refers to an actual powered antenna (like as in amplified?) and not as in an antenna that rises up out of fender, as I believed.
This may not help the first person with the question, but maybe it will help someone out there who searches for these kinds of answers like I do from time to time.
Posted on Nov 21, 2010
  • 87 Answers
That is usually the antenna. Antenna's do go bad, as AM reception is all based off the vehicles ground system. It could be lose on the vehicle or just quite working correctly. Best Buy can trouble shoot it by using one of their antennas and grounding it to your car and pluging it into the radio, good reception? Then your antenna is bad - still no reception? The probably the radio.
Hope that resolves it.
Posted on Jun 02, 2009
  • goldenhound Sep 29, 2010
    I went round and round with this same problem. I had *perfect* ground on my antenna, and tried radio after radio being told by salesman and techs that the AM receivers were extremely poor quality anymore. NO AM RECEPTION - a wall of static.
    Turned out that the ground isn't the only thing that goes bad. The center lead also *MUST* be hooked up. This happens all the time when people yank the antenna lead out of the radio. If you get good ground but no continuity off your center lead in the coax, you will *NOT* get AM reception. Period.
    New Friend:
My pioneer had the same problem after installing via the wiring harnesses into my BMW. Pulled it back out, there was a blue wire with white stripe out of the unit, and a blue one coming from the harness. Joined them up, BINGO. Perfect reception.
Posted on Feb 25, 2013
    New Friend:
My problem was a little different the am went out after while I took the faceplate off of my JVC KD r300 and would replace it and get am reception for a while then it would clock out again face plate comes off on my model inserting handle of a nail clipper on the left side slot installing it requires that you put the right side in first where there are clip Grabbers and then click it shut but you'll have to align a few things on the inside.
Posted on May 11, 2016
  • 6 Answers
These people are just shooting in the dark and hoping it solved the he problem. The actual solution is buying the right antenna adapter since your VW has an amplified antenna it needs a turn on lead from the new H. U. since the factory has been replaced that is no longer present. There are two antenna adapters one without a turn on lead for Mercedes and such and the VW specific. Buy the VW specific and problem solved.
Posted on Mar 04, 2015
SOURCE:
I have a JVC KD-S37 car stereo and need the manual plus the remote cuz i cant change the color and setting please can you help? thanks ferrarisandra325@gmail.com
      • vcwuaaaaasuvork5cyii=
  • Attention JVC consumers!
  • JVC's Consumer Customer Care Center can help you with most product or service related questions you might have. This number is for home-use TV's, VCR's, DVD's, car audio and portable electronics:(800) 252-5722
  • JVC Pro Support Page
    Dec 05, 2014 | JVC Kd-s37 Car Audio Stereo...
    Replacement faceplate for a jvc kdhdr50
    Are there other faceplates that are compatible with my jvc kd-hdr50 because someone stole mine and i cant find anywere that sells just faceplates
    Jun 27, 2012 | JVC KD-HDR50 Car CD/ MP3 Player
    Jvc KD-R531 ipod
    Contact JVC customer service please.
    Jun 27, 2017 | JVC AM FM CD DET FACE CAR STEREO
    I have a JVC KD-HDR50 in das cd/usb reciever in my car. I press the SRC button and it goes from am to fm to cd to aux in to sirius. Now the sirius option won't come up, what do I do?
    try resetting your deck. the reset switch should either be an unmarked indentation about the size of a pencil tip on your face, or behind a small hole on the subpanel behind your face.
    Feb 01, 2011 | JVC Sirius KD-LHX500 CD Player
    CAN I HOOK UP MY CELL PHONE TO THE RADIO? JVC
    unfortunately this model dosnt come with bluetooth capability, you can only plug in your mps/ipod etc.
    Mar 17, 2010 | JVC KD-G140 Car CD Player
    JVC KD-SH9101 RESET06 and the front panel don't move normally
    ok from what i can gather it sounds like something broke inside the unit and you might wanna replace it. Im sure you can find a much better radio really cheap. I had a similar JVC model and it gave me headaches. I think you will love this model instead. Trust me its soooo much better and priced really well for its capabilities.
    JVC KD-R800 30K Color-Illumination Single-DIN CD Receiver with Dual USB 2.0 for iPod/iPhone and Bluetooth
    Aug 31, 2009 | JVC AM FM CD DET FACE CAR STEREO
    Help
    Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
    Aug 01, 2007 | JVC KD-G720 CD Player
    JVC KD-PDR30 Car CD/ MP3 Player Logo
    14,477 people viewed this question
    Top JVC Car Audio & Video Experts
    xxxxxx xxx
    Dalynn Turner
    Marvin
    Marvin
    Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
