Question about Karcher 2500 PSI Pressure Washer
Karcher g2600 engine surges at all sppeds
Engine starts easy . have water going in and free flow coming out. engine surges at any spead and will not settle down. Played with chke and makes no big difference. when it surges high then have pressure when low boviously little more thant hose pressure. Honda GJAEA engine
5 Suggested Answers
  • 21 Answers
SOURCE: Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
Posted on May 29, 2009
  • 174 Answers
SOURCE: poor pressure
i had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
Posted on May 31, 2009
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
  • 420 Answers
SOURCE: Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Posted on Jul 20, 2010
Karcher k3.00 lack of power
Are you using the same water supply as before when you had good pressure? Some house water lines have pressure reducers to protect your pipes and appliances. This can restrict the water flow and reduce the pressure the machine develops. If the flow surges (good, then weak, then good etc) you are not getting enough water to the pump. Try a larger diameter garden hose (5/8"). If you know where your water line enters the house, try the hose bib closest to it. Often times it is at street pressure instead of (reduced) house pressure.
Aug 03, 2014 | Karcher Garden
My karcher k2.20 motor keeps running even when i release trigger and water is pouring out from inside the casing....
You need to get the casing out of your way so you can see exactly where the water is coming from. Best guess, just starting out, is that the pump has an "Easy-Start" valve on it that is not closing. This Easy-Start device is just a small valve that has a ball and seat and spring in it. Very simple. It allows all water flow to be diverted until the engine RPM comes up to "cranked" stage.
All that said, it could be something else entirely. So, we gotta have some eye-ball input at this point (if there doesn't seem to be an Easy-Start valve leaking).
Don
Mar 23, 2012 | Karcher Garden
I have a Karcher G2600 OR, It sprays with full pressure for 1 secound and then it stops for about half a secound. it keeps repeating this constantly. I have checked the seals and the pressure valve and...
sounds like a bypass valveproblem try backing off your control valve and see if it clears up. also make sure your hose and nozzle are free from debree.
Jul 05, 2011 | Karcher Garden
QUE TIPO DE ACEITE USA LA KARCHER GC160
tengo una maquina honda gc160 5.5
modelo g2600 vh con seria 152 428
Jun 29, 2011 | Karcher 2500 PSI Pressure Washer
How do I replace the surge tank on 2002 GMC Yukon. Need to check for a leak in tank. Could leak be in hose from surge tank to water puml? Can not see any water leaking except for water on right...
Surge tank?
Are you talking about the coolant reservoir? There should not be any water in the system. Only engine coolant.
Anyway, it is easy to remove the coolant tank. They are typically secured by two or three 10mm screws, and one or two hose clamps.
It is a pretty easy procedure that you can do yourself. Recommend a youtube search if you need video.
Feb 09, 2018 | GMC Yukon Cars & Trucks
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
I have had 3 Karcher pressure washers all experience the same problem and so have two of my neighbors. Our area has very hard water and it causes problems with the washer not bringing up the pressure when...
If your water is that hard (and it appears it is) WD40 will NOT solve the problem. You should look into a water softener. However, chances are that a small, inexpensive model will not have the flow capacity required for a pressure washer. You'll likely need to look at a larger, whole-house model.
Use vinegar to through the machine's "soap" dispenser to break up the hard water deposits or a heavier solvent such as CLR which is available at most retail outlets.
Nov 04, 2009 | Karcher K2.26 Electric Power Washer
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Sep 20, 2009 | Karcher Garden
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
197 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
