Whirlpool 8,000 BTU Electronic Window Air Conditioner - ACQ158XR
Problem for Whirlpool 8,000 BTU Electronic Window Air Conditioner -...
Whirlpool Air Con Drainage issue
By cbsoupman on May 31, 2009
My 8000 BTU Whirlpool Air Con is draining water all down inside the window sill. Is there supposed to be a hose/pipe that drains to the outside???
Comments:
May 31, 2009
- Appears to be a closed unit. No tube or opening outside is apparent. Advice?
May 31, 2009
- It is dripping down the inside of the window sill (causing water damage) instead of out the back somehow. I'll remove the cover and check it more thoroughly. Thanks for the help.
Solution #1
posted on May 31, 2009
Not Rated)
scspriggs
Rank: Guru
Rating: 91%, 602 votes
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
Comments:
May 31, 2009
- All I can say is there has to be some way for the condensate to exit to the outside.
There is no A/C in existence which does not produce condensate, and there has to be some way to remove it from the unit.
Since you don't want the condensate on the inside of the house, it would follow that the unit has to be designed to allow the condensate to flow to the outside.
I can't imagine that there is a "bucket" you have to empty. I assume you have been running the unit satisfactorily with no condensate coming into the house -- is that correct?
Was this helpful?
Yes
No
Popular Solutions for Whirlpool 8,000 BTU Electronic
Questions and Unsolved Problems for Whirlpool 8,000 BTU Electronic
Do you recommend Whirlpool 8,000 BTU Electronic Window Air Conditioner - ACQ158XR?
Answer
Answer
My comfort Zone II has stopped displaying the third zone. What could be the problem?
Answer
My dehumidifier runs but does not extract any water.
Answer
It has an arc protecting plug with a little green lite that shows power and a reset button. The... (More)
Answer
the display on my ac shows 89 when i turn it on and the compressor never kicks on. i turn the... (More)
Answer
extended uses causes the window unit to freeze up and restricts all airflow
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool 8,000 BTU Electronic...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
