Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Frige not cold,freezer working ok
Frige not cold,upper "freezer" is working well or maybe too well
  • Jeff Mallett May 11, 2010
    Hi : Give me the model number, only if the solution dosn't work. Jeff
    Novelist:
  • 103 Answers
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. Look at the heater. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Usually on a circuit board and expensive. Good Luck, Jeff
Posted on May 31, 2009
  • Jeff Mallett May 31, 2009
    Hi I forgot to mention.... If you use the hair dryer to melt the frost and it's something you cant fix. The refrigerator will work normally for a week or two depending on usage and humidity. Good Luck Jeff AKA bluntcow
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
Mar 09, 2015 | Amana Refrigerators
Freezer fine frige to cold
you must check the door seals are ok and if they are you might have a bit of compressor oil stuck in the condenser pipes somwhere this is a regular problem with alot of new fridges youll need to take it to the agents if thats the case
Mar 20, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is working Ok but the fridge is not getting cold
defrost your frige and freezer .reason is it builds up ice in back after awile it cannot get air flow til it gets turned off a couple hours.you will have some water to clean up
Mar 01, 2010 | Refrigerators
Whirpool gold Frige no light or temp display working
I am having the same problem does anyone have a solution?
Dec 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
I have a model ARB2257CSR Amana frige (freezer on bottom) and the freezer is not working I think. there is a sound that comes on and off like the motor maybe is trying to come on... the sound comes from...
Sounds like the overload/relay is going out . If the noise is a " click " , replace the o/relay after checking the 3 terminals on compressor for continuity and each terminal to ground ( copper tubing ) .
Jul 15, 2009 | Amana ARB2257CSR Bottom Freezer...
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
117 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
