Question about Dell (0Y4801) for Inpsiron 600M, Latitude D600 Motherboard
Acer TM 240 only blank screen
Working on a friends acer tm 240, he started it one day and nothing but blank screen I can can run cd rom but then i get one or more unremovable problems but i know that doesnt mean the HD is fried so i did a scan of C got same message. When i did a dir/l of C drive came back with nothing to list but the D drive with dir/l works. Before i tell him he needs a new hd i want to make sure i have tried everyhing ty
    Problem Solver:
  • 5 Answers
Sounds like you are booting from a Boot CD?
Try to run FIXMBR at the command prompt. If the mbr is hosed that might fix it.
You can also try chkdsk /r on the C: command prompt. That will scan and try to fix errors.
Posted on May 31, 2009
Acer aspire 1690
here is what i found aspine 1690 ,tm 4100, tm 4020 uses the same motherboard.
http://us.acer.com/ac/en/US/content/drivers
then download for acer- travelmate 4100 or travelmate 4020 .
Apr 15, 2011 | Acer Aspire 1690 Notebook
I have Acer TM 4150. I has booting problem like when i put on my laptop it gives message to boot from 1- floppy drive 2-HDD 3- Cd Rom also in Cmos it shows no Hard disk or O HDD i restart it again...
Isssue with your Hard Disk... Possibility Data lost, due to power lost, or Bios Battery need to be change... To do So, Press and hold del button while you turn on your Laptop this wil bring you inside you Bios then Check carefuly set date and Time also set autodetect hard drive and set cd-rom first hard disk 0. second then the rest off... press F10 to save your change then restart your laptop then see if it will boot from itself.. if not ...Then put your XP CD on the cd-rom then re-start then press F-12 then chose Cd start to re-install your windows make sure you have your Cd key first then from anoter computer go on the net and download all your drivers for your laptot type down the model off your Laptop then on any browers type exemple; download ACER TM4150 drivers for xp or the one you use.. sample is that.. Good Luck
Oct 01, 2010 | Acer TravelMate 2303LCi Notebook
Acer aspire 5520g black screen, power light blinking
go to acer website ...go to dowloads section..select ur model ..n download latest bios
Nov 06, 2009 | Acer Aspire 5520-5908 Notebook
7720 Travelmate turned off and startet again only once
Try without battery.
If it set the problem, let me know
Check power supply if green led lights up
if not try other power supply if yes
Tell me if you ear or see anything on the screen.
Sep 08, 2009 | Acer TravelMate 5520 Notebook
Acer 8100 tm screen switch broken
i would assume somebody has to open the Laptop and replace the switch alltogether. If you want to pay to have somebody do it for you there is a third party Acer Repair Service. However, if you want to do it yourself, the part is available on ebay. Here's an Acer Repair guide. Maybe a tech savy friend can do it for you.
Jun 20, 2009 | Acer Ferrari 4000 Notebook
I have aproblem with my Acer Aspire 3100 Laptop
locate the cmos/bios jumper below your memory ddr2 modules (J2) you need to be sure to make contact trought this jumper pe.-with a screwdriver, put back your memory modules and turn on your laptop, this process will clear your cmos/bios memory, you will need to setup your dates.
If this will not work you will need to replace your Mobo because of a faulty, we can replace your Mobo if you are interested:
10001 buckwood ave 79925 El paso tx
contact me if you are interested
support@vcrtech.com
vcrtech@hotmail.com
www.vcrtech.com
Apr 28, 2009 | Acer Aspire 3100 Notebook
Acer aspire one - its died!!!
If it was just the hard drive, I would expect the video to come on and say something like "no boot device."
However, since you went through the steps here and see absolutely no video (even none on an external monitor), I would suspect a motherboard failure.
Be sure that when you hooked up an external monitor that you pushed the Fn key and the appropriate special function key (maybe F7) that switches between the laptop and external monitor. If you have done that (pushed the combination several times to switch displays), then you can be pretty certain your video card (if a separate card) may be bad.
I'm not really sure if this machine has a separate video card. The specs say it's a ATI Radeon Xpress 1100. This leads me to believe it may be a separate card.
If it's just the card that went bad, you can replace it. Otherwise, the motherboard will have to be replaced.
Good luck. You can do that, but if you're not confident, you best take the machine to a repair shop.
Apr 26, 2009 | Acer Aspire 3100-1405 Notebook
Im using acer TM 244 FL and unable to download the audio drivers.
Acer has a program available to download updated drivers. I have not tried it but it should do the trick. You'll find it at
http://downloadyourdriver.com/drivers/acer-drivers.php?kw=Driver%20Acer&gclid=CMTkmbCLs5kCFQoMDQodJDXL6A
Good luck
Mar 19, 2009 | Acer Computers & Internet
Laptop
here are some details below find the right one and take it
Model No: TM 2403NWXCi
Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
RAM: 256 MB DDR2 400 RAM
HDD: 40 GB
Optical Drive: DVD-Rom/CD-RW Combo Drive
Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
Graphics: Intel GMA900
Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
Weight: 2.38 KG
Battery: 6-Cell Lithium Ion Battery
O.S.: Linux
Warranty: 1-Year Global Warranty
Price: Rs. 27,999*
Model No: TM 2424NWXCi
Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
Model No: Aspire 5002NWLMi
Platform: AMD Turion 64 ML-30 (1.6GHz)
RAM: 256 MB DDR333 RAM
HDD: 60 GB
Optical Drive: DVD-Dual Double Layer drive
Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
Graphics: N.A.
Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
Weight: 2.9 KG
Battery: 8-Cell Lithium Ion Battery
O.S. : Linux
Price: Rs. 37,999*
Model No: Aspire 5004NWLMi
Platform: AMD Turion 64 ML-34 (1.8GHz)
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
To u my friend
nothing much buddy ...
HDD: 40 GB
Weight: 2.38 KG
O.S.: Linux
Price: Rs. 27,999*
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 37,999*
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Model No: Aspire 5502ZNWXCi
Platform: Intel Centrino Mobile Technology based Processor Pentium M 735A (1.7 GHz / 2MB L2 Cache / 400MHz FSB) / Intel 915GM Express chipset.
HDD: 60 GB
Optical Drive: DVD+CDRW Combo Drive
Display: 14.1" WXGA CrystalBrite TFT with 1280 x 800 resolution.
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 2 USB Ports.
Weight: 2.38 KG
Battery: 6-cell Battery
O.S. : Linux
Price: Rs. 40,499*
Model No: AS 1641NWLMi
Platform: Intel Centrino Mobile Technology based Processor PM 725A (1.6 GHz / 2MB L2 Cache) / Intel 915GM Express chipset
RAM: 256 MB DDR2 533 RAM
HDD: 60 GB
Optical Drive: 8X DVD-Dual Double Layer Drive
Display: 15.4" WXGA CrystalBrite TFT with 1280 x 800 resolution
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 3 USB Ports
Weight: 2.38 KG
Battery: 4-cell Battery
O.S. : Linux
Warranty 1-Year Global Warranty
Price: Rs. 42,499*
Apr 14, 2008 | Computers & Internet
Computers & Internet Logo
179 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
