We have a tumble action washer. today for the first time, the door suddenly burst open and water gushed out. it was discovered that the cold water did not turn off during the rinse cycle.
  • 15,935 Answers
The Fill valve is not working properly (Stuck open)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Cold water line frozen going into washing machine
If you can find the frozen section and it is easily visible, you should try to defrost it with a hair dryer. The problem will be finding it. It is likely behind sheetrock. If that is the case, then just raise the thermostat and keep the door open to allow for circulation of air in the room to defrost it. Something else you can do if you have an area sensitive to freezing in the house, is find a faucet near the washer and let the water run just a little (drip) to keep the water moving during deep frosts.
Jan 29, 2014 | Kenmore Washing Machines
Washer will not drain and go into spin
Possible bad pump or plugged drain line, door will not open if water in tank
Mar 03, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Front Load Washer Shrinking clothes
check to make sure you water line arnt hooked up backwards. if hot is to cold and cold to hot your washing in hot water when your trying to use cold
Nov 20, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
