Question about Stainless Patio Heaters - Steel Deluxe Residential Outdoor Patio Heater
Kirkland outdoor heater will not stay lit
The propane tank seems to be full, is open and I can get the pilot to light. But, when I stop depressing the button to turn it on it will not stay lit unless I keep the button depressed even fully "on".
  • 306 Answers
The thermocouple is bad. That is the part right next to the pilot light that sense's the flame and hold the gas valve open to the pilot. Take the old thermocouple off and go to hard ware store and get a 18" one of what ever length you need and replace. 5 dollar part.
Posted on Jun 01, 2009
1972 atwood water heater
Check your propane tanks (are they full?), make sure the valve is on, then check to make sure gas is making its way to the hot water tank, if the pilot lights but won't stay lit your flame sensor is faulty.
May 14, 2014 | Water Heaters
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
All Pro patio heater modle SPC54PHW, PHB, PHT, PHS. Pilot will not light and burner will not light.I installed a new regulatoe, propane tank is full. Took the gas pipes apart from bottom to top and no...
If your propane tank has an OPD valve.. in other words if when the tank is disconnected and you open the tank valve and no gas escapes..it's an OPD valve..these are pretty much standard especially on the exchangeable tanks.
The problem sometimes is at the connection hose..it too of course must be an OPD connector to depress the internal ring on the tank valve before any gas will come out.
Chances are the knurled knob is either cross threading or is cracked..and won't snug up enough to depress that internal ring on the tank valve. Or you have miss matched components.. unlikely if you bought genuine replacement parts.
The All Pro Heater you have requires a specific part (fitting) to be added when using a universal regulator (Part number 6122) which is a 3/8 connector male.
This of course is assuming you hear no gas hissing.. cannot light it manually..
Sounds simple..but I have seen this problem on outdoor BB'Q's many times.. cracked knob on the connector hose and a few times simply backing it off and putting it back on.. tight enough to depress that ring..
Best of luck!
Apr 12, 2011 | Stainless Patio Heaters - Steel Deluxe...
The heater is attached to the propane tank properly; however, when I try to light the heater, the push valve does not allow the gas to pass to the heater to be lit. I do have all of the valves open on the...
Typically there is a safety device directly above the pilot light that must be up to temp for the gas to flow. You did not specify if the pilot is lit. If not, hold the lighter at the pilot light while depressing the button for one minute. This allows the sensor to warm to operating temp, thus allowing gas flow. Once pilot is lit adjust the temperature accordingly.
Feb 19, 2011 | Heating & Cooling
Pilot light will not stay lit, have full tank of propane gas
clean or replace the flame sensor
this link is for the parts diagram
http://www.haywardnet.com/inground/products/replacement_parts.cfm
if this helps please vote
Nov 12, 2009 | Hayward H Series Pool & Spa Heater 400k...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Heating & Cooling Logo
1,244 people viewed this question
Top Stainless Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Stainless Heating and Cooling Expert? Answer questions, earn points and help others
