Question about Acer Computers & Internet
Black screen on my Acer 203wbd monitor. Keep getting No Signal message. Have checked all connections.
I have an Acer x203wbd monitor. There is a No Signal message that appears on the screen. I have checked all connections and they are fine. The screen is black.
  • Acer Master
  • 2,404 Answers
Try another monitor on your computer. If you get video with another monitor then you know that your original monitor is bad. If you don't get video with another monitor then you know its something with the computer.
If the computer is the problem. Try reseating the memory and CPU. and also make sure the computer has no dust or dirt in it. If you still can't get no video then the motherboard is bad and would need to be replaced.
Posted on May 31, 2009
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
Aug 25, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
My Acer Aspire R1600 is not getting a signal from the monitor. The acer is connected to a switch which also connects to a Mac. The Mac works fine. I plugged the monitor directly into the acer and still...
Hello, try and see if you can start it with another monitor. Or another video cable, it might be the cable is busted...
If neither of these yield any relief - check if Acer actually starts when you press the power button (it might be monitor does not come up because there's nothing to show if Acer is still dead).
If Acer starts OK, but still no video signal, check its video port, or video card inside.
Jan 12, 2018 | Computers & Internet
I just installed a Acer S211HL LCD monitor. All my connections are tight. I get a No Signal on screen and monitor goes off. what the proble?
If you get a no signal message then check your video card, if the monitor gets no power at all then try replacing the cable, try a different outlet, if none of those work then the monitor is defective.
Mar 04, 2011 | Acer Computers & Internet
Cannot connect my monitor to acer x1700
hi,
Please check on the function keys either on f2 or f3 butoon one screen will be printed.
Yyou will have to press Fn+screen button simultaneously after connecting the external monitor and the display will come on the monitor
Apr 05, 2009 | Acer Computers & Internet
Why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Feb 24, 2009 | Acer X193W LCD Monitor
GETTING A NO SIGNAL MESSAGE FROM MONITOR
Hey,
Press a few buttons on the keyboard incase the computer is in sleep mode.
If you still don't get picture at all, the issue is with the computer, please test the screen on another computer to see if the problem persist there, if it works perfectly on the other computer then theres a problem on the computer and I suggest you get someone to look at it.
Thanks,
Ekse
Feb 15, 2009 | Acer AL2216WBD LCD Monitor
No signal message on screen while working
what type of connection to the monitor are u using
Jan 02, 2018 | Acer X241Wsd Monitor
No Signal?
Loss Of Signal - LOS Short for Loss Of Signal, LOS is generally an indicator on a networking device to ... has no connection on the other end, network is improperly configured
Good Luck, This should get your signal back again for ya.
Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Al2416WD LCD Monitor
Computers & Internet Logo
186 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
