Question about Singer Sewing Machines
Singer CG-500 Bobbin not moving.
Bobbin does not move. It's clean, needle is not the problem. Almost new machine.
dupina
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
  • 69 Answers
SOURCE: Excess bobbin thread under the fabric
I know you hate to hear this but you are probably threading it incorrectly. Make sure that the presser foot is in the up position when you thread the machine. This ensures that the tension discs are open and the thread makes it in between the disc.
Posted on Mar 01, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
miket756
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
Singer 3232 machine was sewing fine now motor runs but needle does not move up and down
Check if the machine is in the bobbin winding mode. To wind the bobbin, the bobbin spindle has to be moved to the right. (The hand wheel will not turn if the bobbin spindle is in this position.) If it is, move the spindle to the left.
If the hand wheel turns, then check for a thread jam. Remove the top thread and take out the bobbin case. Gently turn the hand wheel forward and backwards until the thread comes free of the hook in the bobbin race. Follow this by cleaning any lint from the bobbin race of the sewing machine.
The last possibility is that the belt has failed. This belt transfers the energy from the motor to the needle bar. One source of the belt is http://www.sewingpartsonline.com/motor-belt-singer-007158xxl5.aspx . You can find YouTube videos on changing the belt. There are other parts that transfer the forces form the belt to the needle bar. However, I suggest you find a good sewing machine mechanic if any of these parts fail.
The manual has good pictures of the bobbin spindle on page 11 (page 18 of the PDF). Singer has the manual on their support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf .
I hope this helps.
Jul 28, 2017 | Singer Sewing Machines
I have a singer 7466 and the bobbin won't load error code 88. please help!
An 88 error code is a generic one. It could mean that the needle isn't moving properly when the machine is turned on, there could be a problem at the bobbin or the computer for the machine is compromised. When did the error occur (regular sewing or bobbin winding)?
First, make sure that the needle is at the highest point with the hand wheel. Turn the machine off and then back on. Does the needle move to the side and back to the center? If so, then the problem is elsewhere. If the needle didn't move, I'd still recommend that you clean the area under the bobbin case.
If you were winding a bobbin, try a different bobbin. Check for any burs that might block smooth rotation of the bobbin. If you were doing regular sewing, also try a new bobbin. Check the bobbin case and hook areas for lint and clean them out.
If the error still persists, the machine needs to be serviced.
I hope this helps.
Jan 18, 2017 | Singer 7466 Mechanical Sewing Machine
The needle My singer 337 will not move. It is not the bobbin winder. Any idea what it could be?
Sounds like it's stuck somewhere. I know this website has many user manuals for Signer machines, so maybe check there for further help? Download Free Manuals
Jan 04, 2016 | Singer Sewing Machines
Needle wont move singer 478
I have a Kenmore sewing machine. I'ts about 30 to 40 years old. I have never had a problem with it until today. The needle got stuck down where bobbin is. I don't know if it should be seen by a pro. I can not get the needle out. The Bar on the side will not move either way. help...........!
Jul 06, 2013 | Singer Sewing Machines
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
My bobbin case came out of my sewing machine and I can't get it back in correctly. The bobbin case moves around. I have a singer cg-500/550
I just had this same problem and although i could not find the answer online, I managed to fix it.
If you look at the bobbin case there are 3 different tabs sticking out.
First you need to have tab #1 under the main part of the machine, and #3 over top of the small twisted metal piece below the bottom fabric gripper.
The hard part is to get the second tab into the proper spot. I circled the piece that you need to move in red. If you move the little piece by pushing it with a flat screw driver, you can line up the bobbin case so that tab #2 is under the metal piece and the bobbin case will be properly set.
Don't give up! It wasn't easy to get it back but I did it, I'm sure you can too!
Apr 27, 2011 | Singer CG754 Mechanical Sewing Machine
I just purchased a singer cg-550/500 and after threading the machine and inserting the filled bobbin, I was unable to bring up the bobbin thread with the needle. I followed the instructions carefully but...
if im not mistaken, the bobbin when you place it in the bottom, you have to thread it is as well to the part where the needle comes down and collects and goes back up. please re-look at instructions for placement of bobbin
Mar 05, 2011 | Singer Sewing Machines
The needle on my sewing machine will not move up and down, the handwheel is a little tight and the bobbin winder wont move, how do I fix this?
You are jammed up with thread or material. Clean it out, rethread, wind a new bobbin. Oil your machine and put in a new needle. When you sew, hold the thread ends when you first start out sewing for about 4-5 stitches. Read your manual, watch your dvd on instructions
Oct 21, 2010 | Singer 3116 Simple
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
Sewing Machines Logo
61 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
