Question about HP PSC 1510 All-In-One InkJet Printer
My 1510 sounds like a machine gun before it prints
When the 1510 gets ready to print, it fires off a Klack, klack, klack, sound, then starts to print. This can't be good. Must have something to do with the print head not knowing it is at the end of its run on the right.
Any Help?
  • 3 Answers
Unfortunately not a solution, but my HP DeskJet F2430 is doing the same exact thing. It's just barely over a year old. I've never had any luck with HP products, so I'm not really surprised. My solution: don't buy HP.
Posted on Feb 13, 2011
    Problem Solver:
  • 6 Answers
With consumer-level HP printers, when this starts happening, youre pretty much out of luck. It basically means that the gears that control the position of the inkjet cartridge/print head are being stripped because the sensor that controls their position and tells them when to stop is malfunctioning.
The only real solution I can think of is to replace your printer. I myself have had several printers die in just this way.
Posted on May 31, 2009
Gear klack
Hi Anonymous, that first gear clunk is a " HOLY SOUND" it dwells in the left hand of the Harley God second only to the thunderous roar of the exhaust and the BA DUMP BA DUMP BA DUMP idle, which dwells in his right hand. The Harley Davidson Motor Company purposely leaves that transmission flaw in it's gear. It's what makes a Harley a Harley. It does no harm. Let us pray.
Mar 23, 2014 | 2011 Harley Davidson FLHR Road King
I have an NEC nwtl656 top loader. It will not perform any function as every attempt at choosing a wash setting results in it sounding a beep and flashing all lights on the panel. No washing settings make...
Hi Mark, my friend has one of these machines and we had troubles like that, in the end i found out the "out of balance switch" was a little sticky. You find the switch by opening the back panel and it is lockated on the right side in the top corner. I flicked the switch a few times to hear the klick-klack, and that was it. Turned it on and it worked perfectly. Maybe it helps, good luck. Hebie
May 05, 2011 | Washing Machines
Kyocera Mite KM-1510 printing on half pages instead of full pages
It sounds as if the paper size at the machine is set incorrectly. Try checking to ensure you cassette or bypass if that is where you are printing from is set correctly.
Feb 16, 2010 | Kyocera Mita KM 1510 Laser Printer
A klack noise on the passenger front wheel when
you should replace brake hardware if you did not. use proper brake lubricate and bleed the system after all.
Jul 25, 2009 | 1991 Ford Taurus
Hp 6200 makes machine gun sound before printing, when the print carriage goes all the way to the right is when i hear the machine gun sound, it still prints fine.
This is quite normal with this series of printers. Happens on my 6310. It "machine guns" only occassionally (once a month), and then the gunning noise slows down slowly, then the print starts. Might be shaking the head to clear ink rigorously or something.
Jun 11, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Top loading washer will not spin
Friend,
ngfam1 At your service!
Sometimes this can happen when the connector from the transmission to the drive of the agitator is broken and needs to be replaced.Similar to the drive shaft of a rear wheel drive v-8 car!
Could have sounded like a knock,knock,knock or klack, klack,klack before it happened.
OR sometimes there is no warning at all.
How old is it?
If its 9 years old or more and it's the transmission or any other expensive repair, I would then advice not to put good money into bad and cut your loses. The new machines are so energy inefficient that they can pay for them selves in only a few years!
Less water, gas, electricity, and detergent!!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 30, 2008 | Frigidaire Washing Machines
Washer/Dryer is not spinning
Friend,
Sometimes this can happen when the connector from the transmission to the drive of the agitator is worn and needs to be replaced.Similar to the drive shaft of a rear wheel drive v-8 car!
Could make this sound first, like a knock,knock,knock or klack, klack,klack
OR,SOMETIMES JUST NO SOUND AT ALL AND JUST NOT CONNECTED FROM THE TRANSMISSION TO DRIVE THE ROTATION OF THE TUB!
This means you need parts! and service!
How old is the washer if it is 10 years old or more I recommend being prudish about investing a lot of money in to it!
The newer models are so much more energy efficient, that they save you water,gas or electricity And detergent too!
They can pay for them selves in energy savings in a few years!
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 30, 2008 | Smeg WDI12 Front Load Washer / Dryer
Loud knocking three separate times during cycle
Friend,
Sometimes this can happen when the connector from the transmission to the drive of the agitator is worn and needs to be replaced.Similar to tyhe drive shaft of a rear wheel drive v-8 car!
Could sound like a knock,knock,knock or klack, klack,klack
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 30, 2008 | GE WWSE6260B Top Load Washer
Archos gmini xs 100
New hard drive. Mine died, too. klick-klack, rrr, klick-klack... end.
Dec 29, 2006 | Archos Gmini XS 100 MP3 Player
HP PSC 1510 All-In-One InkJet Printer Logo
465 people viewed this question
Seeker5211
Seeker5211
