Question about RCA RS2302 CD Shelf System
All parts of the system work except the cd player. This seemed to happen suddenly - all disks were working before that time. Help!
  • jsales Jun 03, 2009
    I cleaned the lens but the cd still does not play. It seems that the disk is not spinning. Help!
    Sergeant:
    Champion:
  • 214 Answers
Just put a lense cleaner and run it for about 2 min. if the problem again prerist than open the system and just clean up the lence of the cd-drive....... if still the problem is not solved than it is sure that the cd player's lence have the reading problem.............just get it to the near by technician it will be charged nearly abot 8 to 10$........
Posted on Jun 04, 2009
    Brigadier General:
  • 8,619 Answers
Hi
You need to clean the cd player lens as it might be dirty by using a lens cleaning disc. The RCA lens cleaner disc uses two positions. Position 1 cleans the lens while the disc is being inserted, and position 2 is used for cleaning the lens once the lens is clean enough to achieve focus lock.
1. Open the CD/DVD player tray.
2. Insert the disc, placing the 1 arrow pointing towards the player, and then close the tray drawer or cover of the player.
All parts of the system - pic3.bmp 3. Once the disc achieves focus lock, open the CD/DVD tray, and remove the disc.
Due to tight packaging, the Fiber Cleaning Pad may become compressed. Before continuing with Step 4, raise the nap up using a stiff brush or your finger.
4. Re-insert the disc with the 2 arrow pointing towards the player, and then close the tray drawer or cover of the player.
The unit should now spin the disc. Allow the cleaning to continue for about 10 seconds. More than one insertion may be required to clean the lens.
5. Remove the disc, and close the tray drawer or cover of the player.
If the unit was used in a smoky environment, the dry brush may not be able to clean it. If you suspect that the lens is still contaminated after the initial cleaning, apply a mild solvent such as rubbing alcohol to the pad on the disc, and repeat Step 4.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 31, 2009
I purchase this system or a christmas present I had it put in today and it works great except the cd player will not except the disc. Please help me with this problem.
does there seem to be something obstructing the cd as you are trying to put it in? some inexpensive decks use cd transport screws on the top of the radio, and they need to be removed before a cd can be taken into the cd mechanism.
Jan 18, 2011 | XO Vision XO1915BT Car DVD Player
My dell inspiron cannot boot. On startup dell logo screen appears with only f2 and f12 options then my screen goes black with a flashing dash in top left corner. I cant access safe mode, i cant do anything...
The Operating System in your hard disk gone corrupt, you need new installation of Operating System using boot from CD/DVD.
P.S. Formating of Harddisk is recommended, because it seems the act of virus infection
Good Luck
DO rate if helps
Dec 02, 2010 | Dell Inspiron 1501 Notebook
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Cd-rom/cd-r/rw drive not working....
it's possible that you may need to reboot your computer with your disk for your operating system
May 06, 2008 | E-Machines eMachines Desktop PC
Cd player on RCA R52653
overheating or lens dirty in unit buy lens cleaner cd to clean it
Jan 27, 2008 | RCA 100-Watt Stereo System With 5-CD...
Aiwa Stereo System NSX-F9
insert CD lens cleaner first, then try to load audio CD if do not work change the lens
Nov 24, 2007 | Audio Players & Recorders
Denon 2910 CD player malfunctions
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Nov 04, 2007 | Denon DVD-2910 DVD Player
Problems with cyberlink power dvd player in laptop
hi dear
it ofen happen at some time........drive doesnt play dvd when u use duplicate or pirated dvd disk.........
1 st use a good quality disk of dvd ,,,,,,,,,,,,,,,,,,,,
if problem remail same then imidately contact ur dealer(shop) & replase u r dvd drive............
some time it also happen due to problem in dvd drive.......
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 23, 2007 | CyberLink SW- DVD Software Power DVD...
Cd player cant read disc
Check that the disk is still spinning. If not then suspect the spindle motor
Mar 23, 2007 | Sony CFD-S350 Radio/Cassette/CD Boombox
RCA RS2302 CD Shelf System Logo
109 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
