Question about Sharp EL-1701C Calculator
How do I turn off the Print function? - Sharp EL-1701C Calculator
Re: How do I turn off the Print function?
Press the '2nd' button, press the 'M+' button. 'NP' should appear on the display screen, and print function will be turned off.
Posted on Nov 15, 2007
WOW !!! I have other issues like disabling the funny decimal problems I got when I add ie: 2.2 + 2.2 I always got 4 or a * at the end. But Best Solution gave me a hint by hitting the "2nd"button and "M-" to deactivate the problem I have been suffering. Thanks!!! :D
Posted on Oct 04, 2008
0 characters
3 Points
How to turn print function off
Press 2nd [P/NP] to switch between print and non-print modes. See page 2 of this manual.
Jan 14, 2013 | Sharp EL-1611P Calculator
Can't print due to E displayed. I already pushed the reset button on back of machine and it did not remove the E
The same thing happened to me. Wouldn't feed paper and the printer function didn't work. The E was in the lower left of the screen. I took the ink cartridge out and reseated it and that fixed the problem. It was installed incorrectly direct from the factory as my calculator was new out of the box.
Mar 08, 2012 | Canon P23-DHV Calculator
Calculator still functions, but printer is not printing anything but nonsensical giberish. Canon P200-DH III
Try pulling batteries/power /out/off.look for reset hole usually a very small hole on back. push in with pin.reinstall batteries (check they are good)or use new,if power adapter plug in turn on try to print.These instructions are genetic not specifically for your model. The printing issue you describe is typically a glitch in the program.
Jan 04, 2011 | Canon P200-DHIII Calculator
TEC MA-1650 Cash Register It appears the register has been put into a sub programming mode somehow and we are unable to get register functional again. When Register is switched to Set there is a P...
Perform a status clear.
turn key to blind(must be S key not mgr key) while holding zero key down turn reg on with power switch on right side.
reg will beep once & print reciept saying status clear.
this wil not clear programs or totals.
Dec 12, 2010 | Calculators
The equals key doesnt print anything. but the total is on the screen. how do i get the total to print?
When you have Print function on and the total you want printed on the screen, simply press the button that looks like a pound sign ( # ). This will print whatever is on the screen.
Jun 25, 2010 | Canon P170-DH Calculator
I have a Sharp EL-1701C Calculator
Hi cherycooney,
Thanks for using Fixya.
Apr 15, 2009 | Sharp EL-1701C Calculator
Victor 1212
Switch to P when turning on the calculator.
Jul 16, 2008 | Victor 1212-2 Calculator
How to get the date and time to print?
There is no date/time function on this model. Here is the link to the manual:
Thanks for using and rating FixYa!
Dec 21, 2007 | Sharp EL-2630P Calculator
Printer malfunction
I"m having the same problem. Just started this morning when I turned my calculator on. Any suggestions?
Nov 08, 2007 | Sharp EL-1197P Calculator
it needs fine adjustment to printer by service center.
Sep 15, 2007 | Sharp EL-2630P Calculator
Sharp EL-1701C Calculator Logo
897 people viewed this question
Top Sharp Calculators Experts
D. E. Hev
Are you a Sharp Calculator Expert? Answer questions, earn points and help others
