Question about Goodman CKL24AR24 Air Conditioner
Very hot compressure
68 suction pressure and 350 discharge pressure
  • 585 Answers
Have frost on the compressor suction line moments after start, compressor unusually loud and labored, and overheating, means the system has been overcharged.
Posted on May 31, 2009
  • Bruce Volkers
    Bruce Volkers May 31, 2009
    Also if the suction line does not frost, then the condenser is not being cooled sufficiently. That could be a fan problem or that the condenser coil is insulated from the passing air by a film of dirt. in which a cleaning would restore normal op.
Noma a/c cq120 makes noise in compressor area and casing is hot to touch. Is compressor going? Is it worth to repair or buy new. I'm guessing this unit is 4 years old or more
Possible Causes There are several reasons for a compressor to run too hot, including high compression ratio, high return gas temperatures, and lack of external cooling.High compression ratios are the result of either lower than normal suction pressures or higher than normal discharge pressures. Changes in suction pressure will affect the compression ratio more rapidly than changes in the discharge pressure. For this reason, it is important to keep the suction pressure at its highest possible value.
Causes of low suction pressure can include incorrect sizing of components, misadjusted or defective metering devices (TXVs), loss of refrigerant charge, plugged driers or strainers, and excessive suction line pressure drop.
Although not as sensitive to change as the suction pressure, the discharge pressure can still greatly affect the compression ratio. Keeping the discharge pressure within normal operating conditions is still important.
Causes of high discharge pressure can include dirty condensing coils, undersized discharge line, a blockage or recirculation of condenser air, erratic condenser fan operation, refrigerant overcharge, noncondensibles in the system, and an undersized condenser.
Many larger refrigeration systems with electronic controllers will automatically monitor the temperature of the discharge line and will send out an alarm to alert the owner or service contractor of a potential problem. Regardless of how the discharge line temperature is monitored, it should always be checked as part of any service to a refrigeration system.
A technician should also check the discharge line temperature within 6 inches from the outlet of the compressor. Any temperature above 225 degrees should be investigated and the cause found and repaired.
Jul 26, 2017 | Refrigerators
Goodman A/C, outside unit. I replaced fan motor, run cap, and start cap. Fan still not turning. Power is good, contactor appears clean to new. Slight humm from compressor. What next. Is there a...
If the compressor gets hot and cold on its suction and discharge lines, then try looking for a pressure switch on the wiring diagram or on the fan motor wires, and bypass it. This will test the motor once it has power to it.
If there is a pressure switch and the compressor does not get hot and cold on the suction and discharge lines, then it is probably out of refrigerant, it leaked out.
Nov 15, 2017 | Heating & Cooling
My Oaisis II hot tub stays at 103 and now it's dropped down to 68 degrees for the past 3 days? Could there be a problem with my heater element? Or is there a sequence of resetting the temp buttons on top...
Information on the care of your product and troubleshooting is available here:
http://www.oasisleisure.ca/customer_care/SpaCare.html
Did you have a recent power outage? It is necessary to reset the temperature after a power outage.
Check the temperature setting on your hot tub; if it has defaulted do to a power outage reset to the desired temperature. If it is still set at your desired setting and is operating at 68 degrees then there is a problem that is preventing the tub from reaching the set temperature.
Some possible causes and actions are:
Pull filter (see if light comes on) / Replace filter
Knife valves not fully open / Open knife valves
Pressure switch cut of calibration / Adjust pressure switch
Faulty Pressure Switch / Replace pressure switch
Air leak, check pump suction line / Tighten pump union
Heating element corroded / Replace element
Faulty control panel / Replace panel
Find the Manual for you specifc model for more explansyion on Troubeshootig.
Feb 06, 2011 | Home
Why is the highside 150psi and the lowsidee is 70psi and the compressure is very hot
the unit seems to be at normal pressure but could use a cleaning on the coils of the condensor..but remember after cleaning do another freon check it could show thats it is low that is what usually happens after u clean hope that woked for you
May 16, 2010 | Intertherm P3RA-048K Air Conditioner
No cooling
More than likely, you have a leak in your system and the refrigerant has all but leaked out. What you need to do is call a QUALIFIED repair tech and have him/her locate and fix the leak, then recharge the system. If you continue to run it, you run the risk of burning up the compressor, then you can figure a total replacement for the system.
Sep 01, 2009 | Mitsubishi MSZ09UN Air Conditioner
Bon-Air mini split 1.5 ton, suction and discharge pressures are equal. discharge valve has ice on it. and the suction and compressor are very hot.
Sorry to sat but the tech has no idea what he is doing. The metering device is in the discharge valve, making that line a low pressure, not high. If the "suction" line is hotthen it is running in heat mode.
Jun 25, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Two lennox heatpump 71/2 tons
check the true psi with the line psi to see if same if psi is good in cooling 225 hi and 70 low on 80'day then compressor is fine and i would start checking for temp difference on the reversing valve sometimes this will cause high suction or high discharge psi shift it manually with by energising it be cooling or heating then pull wire and see how it shifts if shifts good then txv on out door unit could be bad what is the psi in heating on the discharge line going to the indoor unit? most prv's are set at about 350 psi r22 as for suction line size its only hot gas in hp mode os no problem their shows in cooling mode as low suction psi ..hope this helps some also make sure indoor coil is clean!....thanks & rate me
Apr 19, 2009 | Ruud UBHC Air Conditioner
Have goodman unit, ac unit running 55 suction, 210 high side. cleaned condenser coils and charge to 10 degrees supercool. suction at 65, discharge 245, why did my discharge go so high
You should have liquid line filter/dryer that maybe restricted or there is a restriction in the orfice inside the evap coil normal operating pressures are 68/ 180
Oct 07, 2008 | Goodman Heating & Cooling
Rooftop unit economizer not responding. I tried to simulate hot ambient temperature, but compressor did not kick in, check the resistance of OAT sensor and it's good.
1.check spare parts of compressure.
2 check wireing of compressure.
3. check voltage.
4.check continuti of compressure.
5. check discharge pressure.
Apr 04, 2008 | Heating & Cooling
Goodman CKL24AR24 Air Conditioner Logo
90 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
