Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
My insinkerator Badger 5 plus 5 is leaking from the bottom plate
I install the unit about 5-6 years ago it is now leaking from a silver plate at the bottom of the unit. It looks like I can remove the plate and maybe install a gasker of some sort not sure it will work. Or do I replace the unit. This is my second unit I never had to replace the first one, I moved to a new house. I have the same problem with my Badger 5 plus. I checked out one of those do it yourself books and determined that there is a gasket that could be replaced. I'm going to remove the unit, take it apart, and see if i can get to the gasket to replace it. I'll let you know what i find.
  • 1 more comment
  • treborzelazn May 31, 2009
    I can't find a parts list anywhere on-line for the Badger 5 Plus model 7A. Has anyone found one? I want to replace the gasket between the motor housing unit and the upper half.
  • treborzelazn Jun 03, 2009
    Well, I can't find a parts list to attempt a repair so I'm going to use the ol' bucket beneath the sink method for a while until I get sick of the work around and get a new one. I just hate to replace it when the motor works perfectly.
  • Stephen Clarke May 15, 2013
    I found a parts diagram at "Grainger.com"
    Problem Solver:
If you need some part, take a look on amazon, here: Amazon com insinkerator badger 5 parts I bought replacement plate from there.
Posted on Dec 10, 2014
Posted on Jul 16, 2009
2 Suggested Answers
SOURCE: my insinkerator Badger 5 plus 5 is leaking from the bottom plate
Flywheel seal needs replacing if disposal leaks from bottom plate.
Posted on Oct 18, 2009
How does the bottom plate come off a badger garbage disposal
Hi, the only plate that should be removed on the bottom is for wiring the power cord to the unit. If there is water leaking, specifically from the bottom of the unit, it's leaking through the enClosure assembly which is not serviceable. If the unit isn't that old it might just be leaking from the sink flange or mounting gasket at the top of the unit which at times can be difficult to detect. Or possibly the gaskets at the drain assembly for the unit. Hope this helps ;)
Feb 01, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Why is insinkerator badger plus 5 leaking from the bottom?
Check hose and connection from the dishwasher to the unit. Look for cracks and proper installation.
Apr 22, 2012 | Electrical Supplies
My Badger 5 InsinkErator garbage disposal leaks out of the seam about midway down the unit. I don't know how old it is as it came with the house I bought 3.5 years ago. Is it something I can fix?
if the inner seal is leaking -- it is best just to go and buy a new garbage disposal and install it.
normally when the seals start to go bad in the units it does start to effect other parts of the disposal,, and it is kinda a domino effect.
c...
Feb 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking out of bottom of unit, near reset
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
p
Nov 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a badger 5 plus garbage disposal (5-6 years) it humms
Yes, it sounds like you have a bad motor winding, not allowing the motor to actually work. It is time to replace. Hope this helps
Jul 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
May 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
3,145 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
