Engine just stopped running. I have good voltage on my test track on the workbench ... I am ready to disassemble the engine to see if I can find the problem but thought I'd check with others before hand. Thanks for any help. Fred
Before disassembling check the brushes (metal contacts) are making good contact with the loco wheels and are not blocked with fluff etc. Ensure the loco wheels are clean and shiny so that they pick up the track voltage ok. The brushes are made of sprung metal and transfer the voltage from the wheels via the track to the motor. Check that as well as clean and fluff free that they also have a strong springiness against the wheels for good electrical contact. If these appear ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Testimonial: "thanks ..."
