Question about Magellan Maestro 4040 GPS Receiver
Just want to know if I should have the magellan on when it is being charged. Maybe it will not charge unless it is on.
Should the Magellan be on when it is being charged?
    President:
  • 1,111 Answers
Turn the gps on and go to the system screen, go to the power option and see if the green lights are blinking. then set the power to turn off in 10 minutes. the gps will go in stand by till the unit either moves or you hit the power button again. if you have a charging problem on your magellan, i can help you get it fixed.
Posted on Jun 03, 2009
Turn on get a screen saying magellan thats it
  • Check if the unit is fully charged. Because if the unit is not charge you will just stay in the magellan logo.
  • If the unit is full charge and still stay in the Magellan logo find the reset button and press and hold the reset button for 15 seconds while its on and then release.
  • If still the same thats the time need to call the technicall support hotline of magellan if they can repair it free of charge.
  • If you need clarification feel free to reply to this solution.
Jun 12, 2010 | Magellan Maestro 4250 GPS
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Magellan Maestro GPS #MM3225. Screen display this
The unit is now connected to your computer, and you can actually access its filesystem through windows. It is also charging the battery in the unit. I wouldn't want to mess around with the files, though, unless you know absolutely what you are doing. Plus, it's also a good idea to turn the unit off before removing it from the computer.
Apr 18, 2010 | Magellan Maestro 3140 GPS Devices
Magellan 405 won't take a charge from the car
hi tc76,
plug it in and let it charge for awhile using a know good charger, like the car charger. it has a indicator light to let you know its charging.
now press and hold the power button for up to ten seconds until it starts. if that fails
this is a very common problem for the models listed below.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
bill
Nov 29, 2009 | GPS
Magellan maestro 3140 wont power up/start anymore??? Is it dead?
hi ohh_bambino plug it in and let it charge for awhile using a know good charger, like the car charger. it has a indicator light to let you know its charging.
bill
Nov 19, 2009 | Magellan Maestro 3140 GPS Devices
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
Nov 09, 2009 | Magellan Maestro 4000 GPS
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Roadmate 2000 will not charge
charge it up for a few hours, then hold the power button for a few secounds till it starts. if that fails, hit the hard rest on the side. it should start right up unless it has a proplem with the power port, which is a common problem on a lot of magellan...
Jun 30, 2009 | Magellan RoadMate 2000 GPS Receiver
My Magellan Maestro 4040's plug is loose
these 4040 and magellan 2000,2200t,2500,3100,3140,4000 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
you can email me through here or email to.... wmetz@comcast.net
Jun 22, 2009 | Magellan Maestro 4040 GPS Receiver
My magellan 3100 won't charge
you cant charge a 3100 with the USB connection. most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
Mar 26, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 4040 GPS Receiver Logo
79 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
