Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
When I turn on the T.V. after a minute or so the color will darken slightly, and turn a reddish violet hue. This will remain like this for a minute or so and then clear up and work fine. Lately I ha
I have a Sony KP-51WS500. When I turn the power on, after a minute the color will darken just a little and turn a reddish violet for a minute or two and then the usual picture comes back, and the T.V. works fine. Weather or not the T.V. is turned on the light on the front will blink five times, and then rest for three seconds. This blinking will always continue unless the T.V. is unplugged.
  • mccartw May 31, 2009
    I will post the answer when I am able to get the job accomplished.
    Thanks for the information on the changing the CRT socket for the Sony KP-51WS500. Do you know where I can purchase the part with directions on how to do the changeover?
  • 822 Answers
Change CRT socket.
Posted on May 30, 2009
My photos come out a pink-violet hue. camera is set on auto.
That is a problem with either old film or poor processing. Unless you're using a filter on your camera lens, colors like that are related to unstable film or poor/contaminated film processing.
May 07, 2014 | Nikon N50 35mm SLR Camera
How do you remove the yellow tint from gray or silver hair?
You can only remove it by bleaching it. Usually though, we merely neutralize yellow by applying a permanent tint, demi-permanent color, semi-permanent rinse, or a colored shampoo in a complementary color, that is a hue that is opposite yellow on the color wheel. The hue most often used is violet.
Apr 10, 2011 | Health & Beauty
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
Only reddish hue color for entire screen
In most cases these CRT projection sets made by Samsung for Akai are notorious for fouled cooling liquid in one or more of the CRT's. The CRT's in most cases are no longer available.
Aug 14, 2009 | Akai PT5598HD 55" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Print colors
You might want to run a cleaning page through it. This uses up more ink that a typical print job, but it will allow you to clean the heads and force ink through them.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
The image turns a reddish hue and the image expands after about 15 to 20 minutes of use. The Windows icon on the start button disappears into the left side of the screen after 2o minutes of running. I had...
Hello Richard.
Make sure that the monitor cables are properly connected when the colors change sometimes is related bacause the connector to the PC is lose (or at the monitor). If the problem persists, try with the power cable.
Jun 28, 2008 | Computers & Internet
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
