Question about RCA 14F512T 14" TV
Turns on and off at all times of the day and night
All night long this TV has started turning on and off. I have had to unplug it. When I plug it back in, in the morning I can watch sometimes and sometimes it turns off. It will turn on and off all in a matter of 60 seconds, over and over. The only way to turn it off for good is unplug. i'm having the same issue. Tv keeps scanning channels, doesn't respond to remote. deff should be a recall.
  • 822 Answers
Resolder pcb. its a cold solder.
Posted on May 30, 2009
Tv repeatedly turns on & off by itself
Given the age of that unit, It may not be possible to get parts for the unit. The problem you are experiencing sounds like a poor connection on either the receiver for the remote or the main board power unit.
Dec 18, 2017 | Toshiba 40RV52U TV
TV turns on in the middle of the night
  1. If the TV has a timer option, ensure it is disabled.
  2. Check the remote control to see if any of the buttons are stuck that may be interfering with the TV.
  3. Unplug the power cord of the TV from the AC wall outlet for 60 seconds.
  4. Plug the power cord back into the AC outlet.
  5. Attempt to turn on the TV.
  6. Remove all remote controls from the room where the TV is located.
OR
unplug all HDMI sources to see if a device is sending signals in the middle of the night
Oct 03, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
TV TURNS ON BY ITSELF IN MIDDLE OF THE NIGHT HELP
If you have eliminated the obvious things the tv must have a fault...
The obvious things - a night prowler with a remote, a cat walking across your remote, a ghost that likes to watch tv, somebody sleepwalking...
It is possible the infra red signal needed to switch on the tv is not coming from your remote. You can test this by removing the batteries or taking the remote to bed with you. If the tv still turns on then tape over the infra red receiver on the tv to eliminate the chance of some stray infra red beam from elsewhere being the culprit. If that stops the tv turning on you need heavier curtains or blinds or the tv moving perhaps, but if the tv still switches on it has a fault.
There is another thought. Digital TVs and digiboxes are often programmed to wake up periodically to check for software updates. Mine wakes up at 3am but it only checks for software updates and doesn't switch on the tv, but maybe this is what your tv is doing.
A further thought - a tv often has the functions of an alarm clock. They have a sleep function so they can switch themselves to standby after you have fallen asleep and then can wake you in the morning. Perhaps the alarm has been inadvertantly set for 2am?
These days it is rather anti-social to leave any appliance on standby. Rather than unplugging the set every night and worrying about the kids, why not arrange for the tv to be plugged in to a switched outlet so the kids can switch it on or alternatively use a cheap plug-in timeswitch to prevent the set switching on in the wee small hours...
Apr 16, 2017 | RCA F25442 25" TV
TV turns off when you change the channel
sounds like a power fault, prob just weak capacitors if you can change them it would not cost a lot to replace them, when you change channel it draws more power and if its at its limit it will turn off as the capacitors cannot take it. few £'s or $s to get the replacement capacitors, you will probably see the blown capacitors on the power board as the will not have flat tops they will be rounded, change them same for same i.e 16v 330 for same 105c type would be best. it will say this on the capacitor.
May 27, 2017 | RCA TruFlat 27F520T 27" TV
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
Microprocessor or EEPROM circuit = difficult repair,could be
expensive......T.
Oct 24, 2007 | RCA 14F512T 14" TV
TV refuses to stay on
I'm the OP of this, and what I did was had it unplugged for about 2 days, plugged it back in and it has worked since.
Aug 23, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
My TV turns on and off randomly!
Remove the rear cover & turn set on, pull all the connectors off one at a time and push back on. I have had loose connectors cause this problem, and by doing the above has fixed it. Note do the pull off and push back on of the connectors, with the tv unplugged from the AC outlet.
Jul 14, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
RCA 14F512T 14" TV Logo
191 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
