Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
LG DUCTABLE SPLIT TYPE A/C PROBLEM
IN THIS SPLIT A/C THERE IS NO COOLING WE CHECK&CLEAN ALL CAPILLARIES,COMPRESSOR, NON RETURN VALVE,OK **** LIQUID LINE IS SO HOT SUCTION ALSO WE CANT SOLVE PLEASE HELP ME
  • 822 Answers
Check filter and thermostat.
Posted on May 30, 2009
  • 3,267 Answers
What you have left out is the thermostat and they relays(electrical) which are activated by the thermostat. Another point is the door closing button near the bottom right side mounted on the body of the fridge. Check it out too.................................sodeep
Posted on Jul 26, 2009
My compressor worked great until recently. It operates as before but will not build up more than 40 psi. It is rated to 135 psi
problem could be in the non return valve in the compressor line to the tank
most likely in the reed valves/poppet valves in the heads
reed valves split , poppet valves broken springs
May 30, 2016 | Air Tools & Compressors
I have old Ingersoll Rand compressor type 30 model 15T serial # 243496 Blow fuss when restart ?
Probably a faulty non return check valve, when the unit reaches pressure air in the delivery pipe is vented down at the pressure switch. If the check valve is passing back this will cause the unit to try to start against a pressure causing it to pull high amps and trip. If there is a constant hiss coming from the pressure switch when the unit stops it will be the non return valve. There should be a short hiss of air when units stops If there is no hiss at all when the unit stops it could be a faulty pressure switch. If it is a quick fix would be to create a small leak on the delivery pipe to vent the line down.
May 28, 2014 | Ingersoll Rand - Rand Type - 30...
I have a Bryant 561030 the low Pressure is 68PSI and the head pressure is 350+ I'm not getting any cooling i cleaned the condenser but it still giving me the same + pressure
Have you changed the inside filter or cleaned the inside coil?
Also if you have a amp meter check the amps the compressor is pulling compare it to the nameplate rating.If the amps are high you may have a bad compressor.
Im assuming your running r22.You may also have a bad capillary tube or expansion valve depending on what this unit is using.
Jul 18, 2011 | Heating & Cooling
No cooling LG
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My 1 hp. 12 gal. air compressor is not building air pressure the motor runs the pressure won't go above 20 lb.
It could be that the input air filter is badly clogged. I might more likely be that the Non-return valve on the air tank input is not sealing properly and not allowing the tank to build up pressure. This valve is at the end of the main pipe runs between the compressor and tank. It could also mean (less likely) that the poppet valves inside the compressor cylinder head are not sealing properly. Other faults could be worn rings on the compressor pistons or a bad seal between the compressor cylinder head and block.
To check the Non return valve allow compressor to build up some pressure and then loosen union nut on Non return valve. There should be some air released at first but should stop if valve is ok. If leaking remove valve and check for dirt and clean. If valve still leaks replacement is the only fix.
Sep 14, 2010 | Craftsman Air Tools & Compressors
Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
Jul 17, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Ac compressor not coming on 2001 cadillac deville
hi there,
there are several test to be done and analysis on trouble shooting ac performance.if the ac run smoothly but insufficient cooling effect was taken after recharching factors can be obtain in poor performance of compressor,clogging of tubes mostly on capillary tube and expantion valve.this main factor
contribute on ac in sufficient cooling.compressor performance can check the on the discharge valve by mounting a hi side pressure gauge and check the lost compression effeciency.while the compressor is running if it can discharge a pressure higher than the operating pressure w/o losses on psg. you have good
compressor performance.but if can not maintain a operating pressure you replace compressor.if the compressor is good check the capillary tubing by purging and cleaning the system,obstruction can't expand the freon inside your evaporator,have a nice day don't forget to fix my rate.also recharge exact amount freon on the system don't exceed.poor refrigeration was the result,no cycle will occured.
May 04, 2010 | Air Tools & Compressors
Capillary tube replacement
The True TSSU-60-16 uses an oversized (134A) refrigeration system with air flow directed at the pans.... if the capillary tube is plugged it will NOT cool at all.. most of the time a restriction (plug) is at the drier where the capillary tube goes into it.. as it is smallest passage in the system...hope it helps
Sep 02, 2008 | Refrigerators
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
879 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
