Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Is a craftsman 19.5hp 42'' deck mower gravity fed?
Sorry i typed the wrong hp earlier. bear with me. it's hot and i've worked to no avail trying to fix this mower. countrylady
  • Samuel Charles Spriggs May 11, 2010
    Hello countrylady,
    I'm assuming you're asking about the fuel system -- I've never seen a fuel pump on a riding lawn mower, but that doesn't mean that would never happen.
    What are the symptoms you're experiencing with starting it?
    Charlie
MY GAS WILL NOT RUN FROM TANK
Posted on Sep 15, 2009
  • 61 Answers
What belt drive or blade
Posted on Sep 06, 2009
Drive belt getting hot and slowing down
check bearings of all spindles the belt drives Find the one that has seized and replace the bearings. They all suffer from water and dirt getting in
May 30, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Should the fuel filter have gas in it while running - Craftman lawn tractor - 917.271024
Yes, fuel system is gravity fed. If there is fuel in the tank, there should be fuel in the filter.
Aug 29, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have an Craftsman 17.5 Hp 42 in mower and the blades are making a loud noise when they cut on. I have cleared all of the junk that was under the deck and I found out that the pulley is hard not move. How...
You can try to take off the pulley and soak it PB blaster or WD40 to loosen whatever is going on inside there, because it sounds very much like your bearings in that pulley are wasted! You might have to buy a new pulley assembly or bearing if that does not work. I am leaning towards the second solution. Try it what have you got to lose?
Jun 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
WHERE IS THE FUEL PUMP ON A CRAFTSMAN 20.0 HP 42" MOWER?
this is a gravity fed system as the fuel take is above the carb and the fuel drains down towards the carb and is fed with a fuel float and a needle and seat valve...good luck
Apr 07, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
How do I drain gas from tank craftsman ys 4500?
try pulling the hose off from the carb and hang it into a pan so that gravity will help it drain into the pan...good luck
Mar 27, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a 19.5 42inch deck riding mower and no gas
just wanting to know where the gas line and air filter is on a craftsman 19.5 hp twin 42 hydro is
Sep 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
21hp Vtwin riding mower quits after it runs out about one half tank of gas and the outside temp is hot (90) degrees. Filling the tank I can then start the engine and it rus ok. What is going on?
THE V-TWINS HAVE AN EXTERNAL FUEL PUMP AND IS GRAVITY FED FROM THE TANK TO THE PUMP. MAKE SURE THE FUEL LINE IS IN GOOD SHAPE AND THE FUEL LINES ARE BELOW THE FUEL TANK LEVEL ANT TIME THE FUEL LINE GETS ABOVE THE FUEL LEVEL IN THE TANK FUEL WILL STOP FLOWING TO THE FUEL PUMP CAUSING THIS PROBLEM
Aug 10, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Is a craftsman 17hp 42" deck mower gravity fed?
does your ower have a solenoid at the bottom of the carb? if so then it could be that or a fuel filter problem or a relay i have had the same problem with mine, Dan
May 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Part number for deck bearing
If you could get me the number off tractor I could maybe find you one .
May 08, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
154 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
