Question about Compaq Presario Notebook
Broken DVD tray
My dvd tray has broken away from the slides and now won't close.
  • 256 Answers
Do you feel adventurous? If so, there should be a screw in the bottom of the computer that holds the drive in. With the power on, open the drive then turn off the power. Unplug the power supply and remove the battery. Remove all cables from the computer. With the computer upside down, place a CD on the bottom about where it would be inside the computer. Remove the most logical screw that is a little farther away from the open door than the edge of the disk. Gently pull on the open door to remove the drive. If the drive will not come out try another screw, etc. When you get the drive out, youcan see if you can fix it. If you cannot fix it, you may want to get a replacement drive.To replace the drive, insert the drive into the computer and replace the screw(s).
Posted on May 30, 2009
Portable DVD player won't recognize door is closed.
My guess would be that the switch inside that the tray hits to tell the dvd player it's closed is broken.
Aug 23, 2012 | Philips portable dvd player phillips...
Samsung dvd R155 disk tray won't open/eject
1) try to clean the button with special contact cleaner spray
2) if this work, is o.k otherwise use the r. control and try to open the tray if work, is obvious the button was dirty. If doesnot work, you must the DVD player.
3) inspect any belt and replace, and lube any shaft +gear with small lubricant( vaseline) and replace any parts broken.Tight any wires connector very well and clean it.
4) if doesnot resolve the problem you must go the repair shopt TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
DVD tray stuck in the closed position
Is it jammed?
Still has a CD/DVD still in it?
Is so try cycling the power to see if it will kick it out.
Otherwise it's most likely a hardware problem like a bad tray motor, broken gear, or perhaps a bad/stuck switch on the tray assembly.
If it's still under warranty, call the manufacture technical or customer support for a possible replacement.
Jul 20, 2010 | iLO DVDR04
360 tray opens and closes by itself
broken faceplate or broken dvd tray. Call MS support.
Mar 20, 2010 | Microsoft Xbox 360 Console
Display flashing Hello and clunking sound from DVD RW. Will not change from Hello nor will it open or close
sounds like you have broken piece moving around on the inside or broken dvd inside my youngest son put a music cd in my dvd player and didnt put it in right and it broke causing player to make clunking sound and door refused to open. The broken cd was found when player was opened up and sorry to say the tray was broken because of it
Aug 09, 2009 | RCA DRC8030N
Rio HT2030 disc loader will not open
I have had the same problem. There is a rubber ban that acts as a drive belt to open and close the disc loader. i took the cover off and then the disc loader cover off to expose the bubber ban. Then i replaced it using two rubber bans from my daughter's braces and reassembled. Works great again.
Dec 23, 2008 | Rio HT2015 DVD Player / VCR Combo
SLIGING DOOR FOR SINGLE CD IS BROKEN
if the door opens and closes dvd player may be faulty
if the DVD tray wont open the disc is stuck inside try Turing it off by the power point wait 3 seconds then back on if disc still doesn't come out (YOU) may need to be remove manually which you need to take it apart
Jul 07, 2008 | Televison & Video
Dvd Ejection
There is a small switch inside the unit mounted at the door stop, or on a cam that drives the door that is broken or out of alignment. Good Luck
Jul 14, 2007 | Apex Digital AT1314DV 13 in. TV/DVD Combo
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
Compaq Presario Notebook Logo
115 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
