Question about Samsung HCM422W 42" Rear Projection Television
Sp43w6hp red gun convergence problem
Like a lot of postings on this site i have a problem with convergence, but just the red gun. Seems worse on the bottom right of the sceen, is fine in the middle/left (or directly in front of the red run) and a little off on the far left. The blue and green are fine. Seems to me that the red just cant focus correctly. Carefully taking the front off the TV I can see that there are four resisistors?? LDRs?? (not sure what they are) in the middle of each side of the screen. I guess these are used to focus the guns when I use the auto convergence option as each gun in turn fires lines across the screen which intersect these components. Funnily enough the autoconvergence always gets stuck and fails on the red gun cycle. If one of these failing is the problem does anyone know what they are called and how much they cost - it looks like I'm going to have to go to an engineer about this but i would like to know what the likely cost is before I get them out! Many thanks :)
  • dmac1980 Nov 07, 2007
    Thanks for your reply, how much do one of these STK IC's cost if they are still made? And how long would it take an engineer to replace one? thanks.
  • dmac1980 Nov 09, 2007
    Thanks for your reply. Does anyone know how much do one of these STK IC's cost if they are still made? And how long would it take an engineer to replace one? thanks.
    President:
  • 3,130 Answers
You need to get two STK392-040 IC's to replace the defective ones on the convergence board. You DO NOT want to get these IC's from just anywhere. There are a lot of after market or factory reject IC's that some parts houses are sell and these do not last. Only get original Sanyo IC's to replace for the bad ones. I buy mine from here http://www.electronic-repair-kits.com/STK392-040.htm and have had no trouble what so ever. If you are good at soldering, you should be able to replace these on your own and save about 300 bucks or so. If you do not know how to solder or work on printed circuit boards, you really should call in a pro to assist you in this repair.Good Luck
Posted on Nov 09, 2007
  • 790 Answers
Hi!
as i see in your comment.. you have defective convergence correction amplifier ICs. the RED GREEN and BLUE (RGB) is amplified by the STK ICs. your RED convergence is not working good in the STK ICs! Replace the STK ICs a new one to get back the normal colors. Thanks...
Posted on Nov 06, 2007
2 Suggested Answers
harry0000010
  • 40 Answers
SOURCE: Sp43w6hp red gun convergence problem
did you ever do a fluid refill on a crt?.........might be your problem.........
Posted on Feb 03, 2008
Image worse after replacing convergence chips
Sounds to me like you have your red (pR) and blue (pB) connections on your component video cables crossed.
I havent seen the previous post so I could be way off.
Nov 24, 2009 | JVC AV-48WP30 48" Rear Projection...
Shadows (Red, Blue) on the pictures
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Had the same problem , fallowed the directions in that
blog....and it was fixed in 10 min :D
The Guy Ken, who posted it is a GOD !!!!!
Hope the blog helps you and anyone with this or similar
problems !
Jean
Feb 23, 2009 | Sony KP-51WS510 51" Rear Projection...
The screen has blue green green, red outlines how do i fix it
This might be a convergence issue. I can tell you that the site that Jean posted will not fix this problem and could even make things worse. That sight pertains to a specific problem that is common in some Sony sets and should not be used to try to fix any other issue.
Please keep in mind many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present and they can reside even when the set is unplugged.
Feb 19, 2009 | Sony KP-57HW40 57" Rear Projection...
I have a RCA 61" HD projection tv and the convergance is going wack. I tried to do the auto convergance from the menu screen, but still not working right. What could be the problem?
Ken , the poster of that Blog writes........
"The problem is with the convergence via thevoltage on the
color ray gun tubes that get out of adjustment.
They arealso known as retrace lines."............
Give it a try, it's FREE and SIMPLE :D
Had very similar problem, that blog helped me save
hundred's of $$$$ in repair costs ! :D
Hope the blog helps you also :)
Jean
Jan 31, 2009 | Televison & Video
Blue outline around images on tv
Sounds like a convergence problem. I can tell you that the site that Jean posted will not fix this problem and could even make things worse. That site pertains to a specific problem that is common in some Sony sets and should not be used to try to fix any other issue.
Jan 29, 2009 | Televison & Video
CONVERGENACE ISSUE?
If you wish to get more details visit the site linked here. Convergence procedure to PTVs are given. http://electronicshelponline.blogspot.com/
Mar 04, 2017 | RCA MM61110 61" Rear Projection Television
Convergence adjustments
Replace both convergence ICs nuber STK392-040 that should take care of the problem. you can get new replacement ICs at the following link and they will send free instalation instructions with pictures so you can install the new ICs. heres the link.
http://servicemanuals.vstore.ca/
May 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
PT47WX52F Convergence problem, 3-d look, green worse
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Nov 06, 2007 | Samsung HCM422W 42" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Samsung HCM422W 42" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
