Question about Dometic Rooftop RV Air Conditioner
Fan stops duotherm , the a/c runs great for around an hour then the fan stops and the compresser keeps going, turn it off for a while, then runs fine for a while and fan stops again.
    Problem Solver:
  • 7 Answers
The cooling fan for the condenser is probably running, getting hot and seizing up. Check to see if the fan is free spinning after it stops. Take a probe and try to spin it manually. If it turns freely, then it could be going bad with it's electrical windings, the internal coils that create the magnetic field that spins the rotor of the fan motor. I suspect it is seizing up, however, once a fan seizes up, it usually stays that way and won't spin even after it cools down. It could be a capacitor that is going bad and not starting the fan after it gets hot. A capacitor is a small round shaped can type with usually 2 wires hooked in series with the motor it is trying to start. That is what it does, help start the device (compressor or fan motor). Good luck.Ken from Henderson NV.
Posted on May 31, 2009
My airconditioner compressor works fine but the fan will not come on .I remove the cover and find the fan is stuck , It is hard to break
it lose , when I do it sounds like the bearing are rusty, then it will
run fine until it is left set for a week or so and it will not star again
until I free it up again
We borrowed our daughter's Hyundai Santa Fe to make a trip to the mountains on a 105 degree day. It was doing great on mountain highways until we stopped after about 3 hours.
May be a bad fan or thermal switch not working. The a/c condenser sits in front of the radiator. It may be that the load on the engine going up the mountain is too much for just the air blowing across it to keep it cool, and the car shuts the a/c off to try and keep engine temp down. Cruising along on level ground is enough to keep things cool. Going up the mountain means more engine heat and probably reduced speed, which reduces air flow, especially if a fan isn't working.
Let car cool off, start engine and let it warm up without driving. Monitor temp and fans. When temp gets about normal, look for fan to kick on. Then when turning on a/c, look for the other fan to kick on. Don't let engine overheat. If one or both fans don't come on, start there. Check fan motor not locked up, relay working, fuse/wiring good.
Jul 07, 2017 | Hyundai Santa Fe Cars & Trucks
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Ac works fine when fan is on low but fan cuts off after a couple of minutes on high
Bad fan motor. Multi-speed motors have a set of windings for each speed. Your high speed is bad so the only solution is to replace the complete motor. When motors are going bad they will over heat and kick out on the heat safety. As it cools back down it will start again for a short time again until it gets hot again.
Jul 12, 2015 | Coleman Dometic Duotherm Rv Air...
Stops running thermostat
thermostat or relay module issue.
May 19, 2013 | Dometic Rooftop RV Air Conditioner
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
Compressor stops at proper humidity % but the fan keeps running.
Dehumidifiers are built that way. They keep moving air so it is able to keep any change of conditions moving around the room. On a dehumidifier, it the fan stops, your unit will short cycle becasue water will naturally evaporate from the water tank and it would turn on, then off, then on then off. The way it runs now is fine. Running the fan 24 hours on your dehumidifier cost nickels a day. Just let run.
Sep 28, 2010 | Danby DDR2504 Dehumidifier
My benQ bp2 120 micro seris projector keeps turning off
One of two issues. One, the unit keep overheating. Common even with my projector. These things should be serviced and cleaned as dust clogs intakes, fans and exhaust ports. Proper venting is essential. If you have the ability, take the unit apart and use compressed air to blow off all circuits, vents and generally all around. Do NOT use high pressure...just the blow off cans will work fine. Second, the lamp could be on it's way out. Check the hours on the lamp counter. Generally, a lamp life that states it is good for 2,000 hours will last about 1,500 as turning the unit on an off eats lamp life.
Jun 20, 2010 | BenQ PB2120 Multimedia Projector
The lamp on my Infocus Screenplay 7210 shuts down
the projector thinks it is overheating. you may need to replace the temp sensor. it located near the lamp plug. also make sure the fans are both moving.
Jan 24, 2010 | InFocus ScreenPlay 7210 Multimedia...
DuoTherm rooftop compressor problem
What you are telling us is called shortcyling is caused by possable low refrigerant then the electrical overload is stopping the compressor. overheating can accure.it is best a local serviceman can check it to prevent major part damage.pressure and oil safey controls can cause
simular cylcling problems.
May 02, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
219 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
