Question about Craftsman 25cc Gas Line Trimmer
The weedwacker dies when I squeeze the throttle trigger
I have the Model # 358.745501 17" 25cc/1.5 cu.in. 2-cycle Craftsman Weedwacker....When I atart the thing, I squeeze the bulb 6-8 times. With the lever in the START position, I start it and everything is fine. Then I slowly squeeze the throttle (which activates the run position), the thing dies unless I immediately move the lever to the start position.Then it runs smoothly...Got me scratching my head....HELP!
Sol
  • 1,041 Answers
You need to clean the carburetor. Remove and disassemble carb. Use a den Tek Brush, (used to clean between teeth), to clean the small portals in carb. Use a carb. cleaner while cleaning. Make sure the small screen in carb. is free of debris. The smallest of paticles can cause the carb. not to run right. Reassemble the carb. and try starting. If there is no change, then you will need to buy a carb. kit for your trimmer. Replace all appropriateparts: gaskets, diaphragm, needle valve, and the small screen.
Jim
Posted on May 31, 2009
  • Jim Parker
    Jim Parker Jun 02, 2009
    Thanks for the rating Sol. If you should have any questions about drywall finishing/patching, or know someone who does, put your questions to Category:("Tools-Building & Power-Hand Tools") at FixYa.com
    Thanks Again,
    Jim
  • John E Byrd May 14, 2013
    I sort of have the same problem. I have a Craftsman 358.745501 weedwacker. I have replaced the spark plug, spark arrestor, ignition coil, starter assembly wire, carburetor, fuel tank, fuel lines, fuel filter, it started and ran for about 1/2 hour then died out and won't start again. Could it possibly be the fuel mixture? I can't think of anything else.
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Need to know the 2 cycle oil to gas ratio for a craftsman 32cc weedwacker trimmer
My Craftsman 31cc 2-Cycle Gas WeedWacker Model C216.51318 manual calls for a Fuel Mix (gas:oil) of 32:1
Jul 11, 2010 | Garden
What is the gas/oil ratio for the weedwacker
50:1 3 oz of quality 2 cycle oil to 1 gallon of gas
Jun 08, 2010 | Craftsman 27cc 2 Cycle Crank Straight...
Craftsman model 358.791042, gasoline weedwacker wont stay running
let it warm up first and then pull the trigger. if that doesnt work, it might be the diaphram . they are cheap.
May 10, 2010 | Garden
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
3,513 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
