Question about Solar Leviton Decora Sureslide Dimmer 611-6621-i Ivory
How do I install decora sureslide single pole dimmer switch??
The power socket have 3 wires....each wire have 1 black, 1 white and 1 ground wire. the switch have 2 black wire and 1 green wire. which wire do I connect???? I have 3 orange plastic cover.
    Problem Solver:
  • 11 Answers
Ok, first turn off power by finding the break box and switching to off. Then I'm assuming you mean by "socket" you mean the hole in electrical box mounted in or on your wall the dimmer is supposed to mount to. Sounds like your electrician ran the power back to the switch through your neutral/white wire. Your dimmer has a top and bottom, it also could possible have a tiny word imprinted that says "to light" and "+" if not attach the white from your socket to the top black wire on the dimmer, then connect bottom black wire to the socket's black wire...ground wires should connect to each other and to the ground in the wall socket. Use wire nuts to secure, then check to make sure no wires are touching anything except for what they are supposed to me touching...and test it before you permanently attach. Go switch power back on, and try your dimmer...if it works GREAT:) Now go turn off power one more time, tape your wire nuttted connections with electrical tape, mount dimmer and go turn back on the power. Hope this helped! Thanks
Posted on Jun 17, 2009
How do I hook up a Leviton Decora no 5601... I have a white, a red, and a black wire
Wiring is unclear without more information.
Question posted under 4-way switch.
Wiring sounds like 3-way switch is possible.
And Leviton 5601 is single pole switch.
Add a comment and say what load the switch controls. Load means light, fan, motor, etc.
Say if another switch controls same load.
And include what type of device you are replacing.
Include what screws and screw colors are on old device.
When you add a comment, it sends email, and I will respond to comment.
Sep 01, 2011 | Leviton 112-05604-2WS 15A 4-Way Decora...
Replacing a single pole switch with a Leviton decora motion sensor switch do both black wires from original switch connect to black wire of new switch and white wire to red wire
The old single pole switch has 2 black wires.
One black wire is hot from circuit breaker box, and the other black wire goes to load (light, fan, motor)
New device has black wire: connect this to hot from circuit breaker box.
New device red wire: connect this to load wire
New device has white wire: connect this to Neutral wires.
Neutral wires are white wires that are twisted together and covered with wire nut and pushed to back of box. If your box does not have neutral wires, then connect device white wire to bare ground wire.
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 28, 2011 | Leviton R01-PR180-1LI Decora 180 Degree...
There is a wallplate with 2 outlets and 2 switches that control 2 separate lights. while trying to install new switches and outlets, wires came loose and now I have no idea what is what.
Open following link to see illustration:
http://waterheatertimer.org/images/Single-pole-switches-in-4-gang.jpg
Each residential electric box has 1 hot wire. This wire should be black.
Hot wire carries power from the breaker box.
Use tester and find hot wire.
Each device in box connects to the black hot wire using short jumper wires.
Outlets: Hot wire connects to brass colored screw.
Single-pole switches: Hot wire connects to either brass-colored screw.
Neutral wires are usually white, and are twisted together.
Neutral wires connect directly to silver screw on each outlet.
Wire going to lights connects to other brass screw on each switch.
Aug 19, 2011 | Leviton DECORA TWO GROUNDING SWITCHES...
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
Describe your how to install a ipp15-1l Problem
1) First of all you need to determine what device you are replacing. Single-pole or 3-way.
Add a comment any time
Remember you can also take advantage of fixya phone service, where expert speaks to you over the phone while you are installing device. This service is not free.
2) If you are replacing single-pole switch, that is where one switch controls the Load (light fan motor)
Here are instructions for installing ipp15-11 Motion switch for single-pole replacement.
Old switch has 2 insulated wires plus bare ground wire.
Ipp15 bare copper ground wire will connect to bare copper ground wire.
Separate switch wires for testing.
Use ordinary two prong tester, tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to ipp15 screw marked BL black.
The other wire that came off switch will connect to ipp15 screw marked RD red
Hot wire is identified.
Located in back of box are white wires that are twisted together and covered with wire nut. Remove this nut.
Now test Hot wire to all other wires in box, excluding bare ground wire.
Tester lights up on neutral wires. ipp15 screw marked WH white connects to neutral wires.
If your box does not have neutral wire, then connect ipp15 WH white to bare ground wires.
4) If you are replacing 3-way switch, that is where 2 different switches control the same Load (light fan motor.
3-way switch has 3 insulated wires and a bare ground wire.
Note screw colors on old 3-way switch. Dark screw is the Load wire. The 2 brass screws are the travelers.
From the ipp15 instructions, it appears you will need Viza Coordinating Switch Remote plus a sensor device to accomplish the 3-way installation.
If you have both of these devices and want free written instructions, then add a comment and I will verbalize contents from the manual.
Also you can pay a fixya expert to talk over the phone.
5) Leviton also offers technical assistance at 1-800-824-3055
Dec 27, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
I have the power source in the ceiling. I want to run wire to a single pole switch to a ceiling light?
Disconnect 1 side of light. Wire nut 1 wire from switch to 1 side of wire from light. Wire nut other side from switch to light. You now have a switch inline.
Sep 09, 2010 | Leviton 104-05611-2WS 15A Decora Single...
Two slots on back of dimmer. one has single black the other has black AND ground (green) wire. Is this correct???
Yes, this is a single pole dimmer switch. Connect the green wire to the ground wire in your electrical switch box and connect one black wire to the power (common wire) in the switch box and the other to the wire going to the incandesant light fixture. (Standard dimmers cannot be used with CFL type bulbs).
You should be working fine! Remember to turn off the power to the wiring your connecting this dimmer to to prevent both getting a shock and from damaging the dimmer during installation.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Leviton Decora Light Dimmer Switch
Single Pole Dimmer Installation
I'm not sure if this is going to work in your case, but I'm pretty sure it will...
Green to ground (probably bare)
Black to black
White to the red that's not labeled 3-way
wire nut on the red labeled 3-way
That should fixya!
May 28, 2009 | Solar Levitron Decorator Style Slide...
Trying to hook up a dimmer switch it has a red black yellow and green wire the box has a black white and ground which wires get connected together?
For a single-pole installation:
1. Connect the 2 white wires together (one from the source and the other to/from the light fixture) - 2 wires
2. Connect the black wire from the source to the black wire on the dimmer switch - 2 wires
3. Connect the black wire to/from the light fixture to the red wire on the dimmer switch - 2 wires
4. Connect the ground wires - 3 wires
Mar 23, 2009 | Electrical Supplies
Solar Leviton Decora Sureslide Dimmer 611-6621-i Ivory Logo
614 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
