Question about Black & Decker BDTF1010B Tower Fan
I want to clean the dust inside the fan, how does it come apart??
I can open up the tower fan no. BDTF1010W
  • 54 Answers
SOURCE: cleaning tower fan
The best way that I found to clean things like this is to find someone who has an air compressor and blow out the unit. But do this outside! The dust is usually unbearable. This is easier than losing small parts and can't hurt it at all!
Posted on Aug 17, 2008
SOURCE: Black & Decker BDTF1010B Tower
when you take all the screws out slide the back down. there is a screw at the bottom holding it from slideing the 9th screw so to speak. you have to take out the u shaped pin on the rod once that u shaped pin is out thats where you will find all the screws to the bracket holding the moter in place take all those out too. it seems like alot but it is really not.
Posted on Feb 23, 2009
videotransmi
  • 105 Answers
SOURCE: how to open tower fan to clean it
Use compressed air to blow the dust etc. out of the unit.  You can purchase a  can of compressed air from Home Depot or Lowes, or Google "compressed air in a can."  Just make sure you clean the unit outside to keep the dust etc. out of your home.
Posted on Mar 22, 2009
  • 9 Answers
SOURCE: Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
Posted on Jun 04, 2009
SOURCE: cleaning of the fans
When I called Seville Support I was told that you can NOT open fan to clean and may not get it together if attempted (glad I stopped when I did!).
You need to use air pressure. After using much of a can of compressed air such as you would use on a keyboard and not getting too far, I broke out my seldom used air compressor which kicked out enough dust bunnies as to block out the sun. Hint: be sure to use outdoors. I'm happy to report both units working as good as new.
Don't have an air compressor? Ask your neighbor, he'll need the correct nozzle to 'blow air' (it comes in handy for many tasks).
Posted on May 14, 2010
Holmes u tower fan. How do I clean it?
Best way to clean most tower fans - YouTube
? 0:23
www.youtube.com/watch?v=PDnPs7AQu_M
May 9, 2014 - Uploaded by slim alee
Keywords; Lasko,Honeywell, ozari, Holmes, newair, crane, Seville, vernado, etc etc. how to open a tower fan ...
Sep 30, 2015 | Tower Dryers
How do I Open the Vorando Tower Fan to clean
Use a flashlight to look through the vents on the front. You should see screws.
Mar 24, 2014 | Frontgate Vornado Tower Circulator Fan -...
Icannot open fan to clean.
If your tower fan is like mine then in the handle there are two screws holding on the back just remove those and it comes apart.
May 30, 2012 | Dryers
I cannot open to clean
There are two screws in the handle remove them and the back panel comes off if they are tower fans
May 30, 2012 | Lasko 2517 Tower Fan
When powering on the tower the fans start and the tower shuts down. Is there a solution
Your fan is dirty so its overheating, the pc is turning off to protect itself, you should open the tower and clean out the fan
Jun 09, 2010 | E-Machines T5082 PC Desktop
My fan makes a loud squealing noise upon starting
open the tower if you can and check if some obstruction of wire is there or not. caution turn of the pwr before doing that . if no obstruction then the fan has to be replaced. open the fan carefully take it to best buy or wallmart and get it replaced.
it is possible for the older computer that the fan goes bad or moves faster than its normal speed . its a common problem with all brands of computer.
May 07, 2010 | Seville Classics MSC10166 Tower Fan
Grinding noise in tower
Grinding noise in tower If everything on your computer is working fine then it is probaly a fan put your ear in the back of your tower near the power cord and see if you can hear the grinding noise better if you can then your power supply's fan is going out if not its probally one of the inside fans in your tower open up your tower and see if you can find which fan it is if you dont want to do this you should probaly get a tech to look at it it's a pretty cheap fix and it can save your computer from heat dammage
Nov 07, 2009 | Computers & Internet
How do i clean my tower aloha breeze fan
you have to remove the fan housing. it is usually screwed.
Sep 10, 2009 | Tower Aloha Breeze Fan
How do you open up a BDTF101B Tower Fan?
first you have to remove the two plugs on top behind the buttons remove the two screws next you have to remove the base stand and their is one screw you have to remove then you can remove the front cover and you can get to the motor and fan.
May 29, 2008 | Black & Decker BDTF1010B Tower Fan
Black & Decker BDTF1010B Tower Fan Logo
220 people viewed this question
Top Black & Decker Dryers Experts
Are you a Black & Decker Dryer Expert? Answer questions, earn points and help others
