Question about Hayward H Series Millivolt 250,000 Btu Pool Heater H2501
Pool heater will not flame
I have a Hayward h350ed1 and heater does not light. I get no flames. Water pressure is 18 to 20 psi, so seems good. Gas is on and after it tries to fire i can smell it.
i do not have a pilot light as it has a direct spark ignitor
    Problem Solver:
  • 9 Answers
Sounds like a flame rectification probelm...look in the manual for solutions
Posted on Jun 28, 2009
Hayward heater h150 ignites and shuts off
check pilot generator if 500 millivolts to gas valve turn on switch if lowers should light if not check wires could be loose make sure flame sensor is above burner if not it wont sense flame
Jul 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
Why is the flame on but water not heating
check gas pressure if correct check heat rise you might need to slow water flow down
Jun 17, 2014 | Jandy Legacy Natural Gas Pilot Light Pool...
Outlet water gets so hot it ballooned the PVC pipe like an anuresum. Lights and shuts down, assuming that is a limit switch working properly. Filters cleaned last month/water pressure seems adequate.
Your thermopile that tells the heater how hot the water is has failed. It should kill the heat at a temperature of 104f. This also indicates that the limits are not doing their job, as they should be killing the heat at 135f (low limit) or 150f (high limit). Schedule 40 pvc is rated at about 140f.
This many failures at once is rare, and typically indicates that the heater has been rigged. Get a tech out to fix it correctly. You are literally playing with fire.
Nov 28, 2013 | Hayward H Series Pool & Spa Heater 400k...
Yellow flame on hayward pool heater
check gas pressure make sure it is a propane or orfices too big have pressure adjusted
Sep 18, 2012 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400FDN won't stay lit
It is probably not sensing flame. You either have a clogged orifice underneath the flame sensor and you probably need to have the gas pressure assessed, meter size and gas valve pressure adjustment. These heaters need 2" wc of gas pressure.
Apr 17, 2010 | Hayward H400FDN Low NOx Natural Gas Pool...
Does anyone know if the igniter also works as a flame sensor on a hayward h200 pool heater its an electronic ignition heater without a pilot light
Yes it does. Flame rectification is carried back through the ignitor assembly ground. Be sure all the points of contact are rust free between the ignitor assembly and the chassis.
Aug 10, 2009 | Hayward H Series Pool & Spa Heater 200k...
Have pilot light lit but unit willnot come on hayward h350 heater
check millivolt output,if it is in normal range(400-600)check for continuity on pressure switch,flame rollout and high limits.
Jun 06, 2009 | Hayward H Series Pool & Spa Heater...
Hayward H400 runs for 2 minutes and turn off, flames out chimney
Soot on your heat exchanger would explain this. Or leaves or rat nests would do the same thing. You can clean these yourself or get a repairman to do this for you. Just be sure if you have soot on the exchanger use a stiff bristel brush but not a wire brush. The soot as you free it up will be pouder and can explode in a fashion. Be careful and good luck.
Apr 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward Spa Heater ignites for 2 seconds and shuts off.
Sounds like this is a flame sensor issue. It is not detecting the flame.
Nov 06, 2008 | Hayward H Series Electronic Ignition...
Hayward H Series Millivolt 250,000 Btu Pool Heater  H2501 Logo
333 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
