Question about Hayward H Series Induced Draft Abg 100,000 Heater
Hayward Spa Heater H100ID blower will not stay on.
I have a Hayward H100ID Spa Heater. When the filter is on, the fan will run (press.switch is made) and the blower will run for about 10 seconds and then stop. After about 20 seconds, the blower will go on again for 10 seconds and stop again. This cycle will repeat 3 times and then the blower will not go on at all (but the fan will cont. to run). I have cleaned the igniter, replaced the temp.switch and checked all switches(temp.limits and air) and thermostat. If the problem is the ignition module ($$$), how do I check it?
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
Posted on Jun 14, 2009
Fan won't start and won't ignite I have a Hayward h100id
check voltage going in if ok check pressure switch should have voltage on both leads if not check pressure switch or copper tube for clog
May 26, 2014 | Hayward H Series Induced Draft Abg 100,000...
Pool Heater. Hayward H100ID Starts fine and heats for about 5 minutes. Then heat stops. You can feel the blower its just cold air.
It sounds like your pool heater is not firing. I would check several things: the burner might be blocked and clogged, the gas valve might need to be replaced, the direct spark module might be malfunctioning, or the combustion blower might be cleaned. One of these is probably the issue. A service man can repair all of these problems.
Aug 08, 2010 | Hayward 100kbtu Pool Or Spa Propane Gas...
Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward heater not working
You'll never get enough gas from a 20 pound tank. Even 100# tanks struggle to evaporate enough gas to keep up with that heater.
In the mean time, what is the output pressure on your regulator?
Jun 15, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
636 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
