Question about Maxtor OneTouch 4 Plus 500GB External USB 2.0/FireWire 400 Hard Drive
Vista is not picking up my maxtor harddriver but wheni had xp was .
How to get maxtor one touch 4 plus 250 to work on vista
    Problem Solver:
  • 5 Answers
Check the disk management MMC - it's likely that you have another drive letter that is conflicting with the Maxtor.
1. Right Click on the Computer Icon (or in the menu),
2. click on Managment,
3. look for Disk Management(on the left side) and click on that.
4. This will show you all the installed HD's that you have.
Your main HD is probably called Disk 0. IF there are any other HD's listed they will probably be labled "removeable", if it doesn't have a drive letter assigned to it do the following:
1. Right click on the Disk (X) that does not have a drive letter. (it should be a "Removable Drive")
2. Select Change drive letter and Paths.
3. Choose a drive letter from the list that is not used, I suggest W or Z just to be sure.
4. After you do that it should come up in My Computer as an available drive.
IF the External Drive is not listed then you need to change the USB port or try it on another PC to see if it works there.
Posted on May 30, 2009
Can't read HD-- I/O error
"Joecolvette" has probably got it right, I've seen this before. The HDD enclosure circuit board has a fault. Can be resolved by replacing the enclosure. Plenty on ebay, just ensure you buy one with the correct HDD interface (Sata or IDE).
Alternatively, if you have a tower with a spare port, you could take the HDD out of the caddy, install it in the tower as a "Slave" (check jumper settings) ensuring the system drive is set to "Master". Then you can check whether the HDD itself is at fault.
Apr 28, 2012 | Maxtor Computers & Internet
I have a Maxtor OneTouch 4 Plus 500GB external harddrive...I originally used it on a really old dell desktop computer but since then recieved an HP pavilion laptop...the laptop has windows vista. At one...
1.) Right click My Computer
2.) Click on Manage
3.) Click on Disk Management at the left side panel of Computer Management
4.) Right Click on the USB device in the Disk Management panel
5.) Click on Change Drive Letter
6.) Assign an Alphabet from E-Z to the USB device
7.) Click Ok
Go to My Computer and find the drive letter that you have assigned.
Hope it helps.
Jun 02, 2017 | Maxtor OneTouch 4 Plus 500GB External USB...
I need the software to get into my Maxtor one touch 4 plus
all of the documentation and downloads for this product are now available via Seagate, as Maxtor was acquired. They are still supporting all the drives Maxtor produced for the normal periods of time.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
Hope this helps FixYa,
Chris
Mar 22, 2010 | Seagate Maxtor 750GB One Touch 4 Plus...
Windows vista states insufficient space on Maxtor One Touch drive
You could check that the backup software settings are pointing to the correct drive. (I've made this mistake before).
Nov 03, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
My vista computer doesn't recognize my maxtor one touch 4 external harddrive...it doesn't recognize it on my xp either how can I fix this...I have a lot of stuff backed up on this and it is less than a...
HI,
What I would suggest, is to take the drive and install it as a slave drive. Make sure your pin settings on the drive are set to slave, and your main drive is set to slave. Then XP and Vista will recongize it so you can pull the data off it, then reformat the drive and see if you get any errors.
Good Luck
Mark
Oct 27, 2009 | Maxtor Hard Drive
Maxtor onetouch 4 plus its new should I format the drive?
Most likely you need to partition and format the drive, especially a new drive. Doing this all depends on your operation system. With Windows XP and Vista, you just need to install the drive a boot the computer. Locate the disk utility software thats built into the most newer OS.
Mar 20, 2009 | Televison & Video
Maxtor one touch 4 mini 250 GB
try plugging it in and then clicking on it in the computer section
right click on the properties tab and then click on compatibility
click in the tick box and highlight win xp
apply and ok
do not throw ii in the the bin as it can be used as a hard drive in any computer or being mini , in any laptop unit
Mar 22, 2017 | Maxtor Hard Drive
I had my maxtor one touch 4 750 gb external hard drive installed on a dell laptop with windows xp i plugged it into a mac and installed it but couldnt get it to work so i plugged it back into my laptop and...
Hi there, I think it may be to do with the format of the harddrive - see if you used the Maxtor in a Windows XP environment it would have been formatted to suit that OS.
Is the Harddrive formatted to NTFS?
Jul 22, 2008 | Computers & Internet
Maxtor One Touch 4 500 GB External Hard Drive (Windows XP (SP2) - I have an issue with my harddrive, where when I plug it into the USB, initially the power light comes on & beeps but it is not showing...
Had same problem. I shut down computer and restarted and Maxtor was installed and had desktop icon and everything worked then. I then backed up with no problems.
Apr 14, 2008 | Computers & Internet
Maxtor basics external drive
Hi Nuisance101, I recall your running vista. Vista is a nightmare. If you cound only see the troubles we see on a daily basis here at FixYa you'ed understand. It's a common problem with Vista not seeing USB devices, externial devices. It does & then the next second it doesn't. Same for all external devices. I'm am 100% sure the trouble is not your system or your devices. It's Vista. I have gone over dozens of post from vista users. One would think MS has been on vacation since the release of vista. You can look at vista's web site for help for a possible fix, at this link. (I have no faith). MS blames driver software. Your Maxtor drive is external. Henve no driver software.
So it falls into that vista area of one time vista see's the drive & the next it does not.
Either way I though Maxtor addressed vista issues. I prefer Seagate drives myself. Personally know lots of people who's Maxtor's drives have just gone down for no reason. Seagate bought Maxtor.
http://windowshelp.microsoft.com/Windows/en-US/hardware.mspx
Most of the post from vista users, claim users should check vista's updates often. Since Max Blaster did its job, I'm inclined to blame vista.
I wish I could give you a better fix or suggestion but I'm up against vista. That's why I run WinXP Pro. I do not have these problems.
Best wishes Nuisance101!
Mike
Mar 30, 2008 | Computers & Internet
Maxtor OneTouch 4 Plus 500GB External USB 2.0/FireWire 400 Hard Drive Logo
221 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
