Question about Panasonic Lands Phones
Setup sys w/disa answer, send to all ext. then a single voicemail on no answer
I would just like to know the simple version to setup just one voicemail for the whole system when there is no answer.
  • bfooter May 30, 2009
    i have a kx-ta824 system with a kx-ta82492 voice mail card installed
  • Carl Navarro
    Carl Navarro May 11, 2010
    Fairly easy....if you had mentioned what system you have and what equipment. Do you have a voice mail sytem now, or just the phone system?
  • Panasonic Master
  • 2,460 Answers
Not easy. There are about 10 programming steps that are outlined in the Features Manual 1.1.8 pages 15-21 and references. You basically set up Common BV messages and message area that the System Operator/Manager can retrieve.
Full programming instructions are beyond the scope of free support, but the features manual BV is a good place to start.
Good luck.
Carl
Posted on May 31, 2009
DTU-16D-2
Voicemail is usually ext 200 or 300 if it's not assigned on a speed dial button. If your ext has a mailbox assigned the voicemail will greet you or ask for your code. If you don't know the code your voicemail administrator will have to reset the password or mailbox. If your ext doesn't have a mailbox assigned, then it will just give you the main greeting that outside callers get.
Jul 07, 2014 | NEC Lands Phones
How do I set up a private line v/m?
If others have voicemail on their phones then you know your system has a VM circuit card. To activate your voicemail you have to go to the individual who has admin rights to the voicemail. When they log in to their voicemail, they have manager options to reset passwords, activate or delete mailboxes, re-record the main greeting for your business, ect. Hopefully they keep a notebook with this info 'cause no one ever remembers all the steps. Also, make sure your ext is forward-no-answer to voicemail or it'll still just ring and ring. Usual code for FwdNA is 43, and 44 to cancel. Usual ext for voicemail is 200 or 300.
May 05, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Our company uses the PANASONIC KX-T7730 phone system, just wanting to know if customers can call directly to our extension numbers?
if your pbx has a built in disa feature, then you need to program
the DIL (sys. pgm. # 418) to DISA-OGM 1. Then you need to
record an OGM (program 9,1,1) to tell you customers that
they can dial the ext.# directly.
Oct 29, 2013 | Panasonic KX-T7730 Corded Phone
Ringer only rings 3 times and quits
What make and model phone? Are the calls going to an answering machine or a voicemail system?
Jul 26, 2013 | Lands Phones
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
Want to have message "Thanks
Get your manual out and review DISA. A single port is included in the U.S. version of the system. It's the best way to make this work, because a TA-824 doesn't have ring groups except from the DISA card.
Carl
Jun 14, 2011 | Panasonic KX-TA824PK Phone
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Call Pilot voicemail Nortel
Depending what number your extensions start with, you need to go to the programming for the auto attendant and "undefine" the number in the menu. More than likely, it is built as a "thru-dial" and allows callers to punch in the extension. If you remove this, callers will have no other choice but to use the options in the menu. I can walk you through these changes if you want.
Apr 16, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
I am trying to change our company voicemail and the manual (with the company's contact info is, who we bought the phone from) has walked away. Is there a standard code for setting the main VM greeting?...
What Toshiba Voicemail system do you have? Is it a Toshiba or third party voicemail? Depending who setup you voicemail and what version you have. Mailbox 990 is the Intro greeting "thank you for calling xyz company". Mailbox 991 is the main greeting "press 1 for sales press 2 for tech support etc. If you have a toshiba Voicemail. Need to login to 990 and 991 (need to know passwords) Newer versions you can setup just 991 mailbox for both.
Nov 26, 2008 | Toshiba DKT 3010 Corded Phone
DKT's wont ring from transfer
put an "H" after the extension in the voicemail, i.e. 200H, you have to put in your #656 #657 codes into the phones to integrate the voicemail. #656 91, ext of voicemail pilot, hold #657 92, ext of voicemail pilot, speed dial button (program one on the phone if it doesnt already have it), enter the number of seconds before the phone should forward to voicemail, i generally do 16, hold. that should fix that!
May 22, 2008 | Toshiba DKT-2010 Corded Phone
Lands Phones Logo
124 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
