Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door will not stay closed
Press button to close door, door closes. then it reopens. i suspect it has to do with elctric eye safety device, which i would just as soon disable if that will make the darn thing close.
  • 822 Answers
Check sensors and switches.
Posted on May 30, 2009
Upon pressing open/close button kitchen door the garage starts to close but then reopens after 3-4". one must then hold button until door is fully closed. what is remedy?
The problem is that your system does NOT "see" the safety "eyes" sensors. Make sure that your sensors are properly connected to the opener (both sensors should have lights on them, one amber and another green). If they do not, check the wiring and the connections at the opener itself.
Sep 09, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Door starts to open/close only travels 8" then reverses/stops
The problem is most likely with the safety "eyes" sensors. Your system does not see them. Rather than opening even without sensing the safety "eyes" sensors like most older system do, this model apparently has a safety feature built in, that without proper communication between the safety "eyes" sensors and the main console, the door will not operate at all. Some people had reported that in a situations like yours, if they the button on the remote pressed, the door will open/close, though this is not recommended.
Sep 06, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
My Craftsman garage door opener opens fine. It
It could be closing too far or the sensitivity could be set too sensitive.
Lube the springs, wd-40 rust may be the whole problem.
If the door hits and the opener continues to move until the rail flexes upward and then reverses - probably the travel adjustment.
Does the door close and stay closed if you hold the wall button down constant until it closes? - this would indicate a safety eye problem.
If the door reverses before it hits the floor or just as it hits the floor it could be the sensitivity or if the safety eyes are mounted to the track they could be flexing enough to move the eyes out of alignment.
Hope this helps.
Jul 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens byitself
You have 2 floor photo eyes that run a beam across so that if a kid runs under the door it will go back up. If the door wont close and goes back up I would check to make sure those lights on the 2 photo eyes are lined up properly. Here is a link also Click Me If you cant get it to stay close there is a emergency cable that you can release to close the door until you can get it figured out. Lost of good info here as well. If this Info was useful please rate me and have a great day.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garrage door opener ability to close the garrage door
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
The dvd tray will not stay closed
this is a serious problem the disc tray is most probly broken u either replace or ask a xpert aroung ur locality .....................i could not help you out b'cause i cant c the problem with my own eye..........
I HOPE UR XBOX GETS FIXED............
Mar 02, 2009 | Microsoft Xbox 360 Console
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
When remote or door switch is pressed the garage door opener only clicks, the motor attempts to move very slightly. starting capacitor is new.
SOUNDS LIKE A SAFETY EYE PROBLEM.
WILL IT CLOSE IF YOU HOLD DOWN THE WALL BUTTON??
Jul 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
310 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
