Question about Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000
What is the gage that you set for the coil
My lawn mower will not start It will not even gets sparks.We are going to put on a new coil but do not know the gage to set it at
  • 284 Answers
Air gap between the flywheel and coil is.012
Posted on May 31, 2009
Lawn mower running suggish
fuel problem???? ya know carb cleaner works on lawn mowers as well as cars .
Jun 07, 2014 | Poulan "Poulan" Push Mower
Lawnmower won't spark
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Apr 13, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Hu700f won't start
My huskuvarn will not start put a new carburetor and a magnitude coil on it it is brand new and will not start it is a 700f husqvarna any suggestions on it plus like I said a new coil and it is not sparking and not starting please help me out
Feb 18, 2013 | Husqvarna HU700F 160cc Gas 22-in 3-in-1...
Cuts out after 10 mins , no restart until it cools, replace fuel filter,spark plug, has new air filter
Most likely it is the ignition coil that is going bad. It is located next to the flywheel. You can use a business card as a feeler gage to set the gap between the new module and the flywheel.
Sep 19, 2011 | Craftsman 42 in. Precision Cut Plus 24hp...
I have a Toro Model 20070 Electric start Lawn mower. It will not start. I changed the plug and filter. I pulled the plug and there appears to be no spark. When I turned it over I saw no spark. I guess my...
check your mower for interlock switches that might interupt spark for safety reasons.
A chute switch or something like that. Check your owners manual for troubleshooting.
Unplug the keyswitch and try pull starting to rule out a bad switch.
If it still doesnt have spark you might need a new coil.
The coil is right under the recoil cover and are fairly cheap.
A set of hand tools and $30-50 for the part should do it.
Good luck and be careful.
May 03, 2011 | Toro Power Lawn Mower
Murray push mower 22" Model 223311X8A Briggs & Stratton motor idles slowly, coughs & spits, stops in middle of lawn and won't restart. Had tuned up, then brought back for recheck. Still...
There are several additives on the market for gasoline, but only a few of them actually help anything. If the additive is relatively cheap to buy, don't expect much results. Gas that hasn't been treated with fuel stabilizer that is a month or more old loses its volatility and can cause issues with engine performance, small and large.
All you guys on the block need to make sure you're using fresh gas, Clean SAE 30 Weight Oil for the Briggs Engines and good clean air filters. Also you can tell when gas is going stale..it starts smelling kind of like turpentine....a smell you'll never forget.
Jul 11, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Lawn mower won't start
Carb is most likely gummed up and will need cleaning. Anytime a gas motor is store through a season, you should use a product called "stabil" in the gas to prevent gumming up. Also check that there is a strong spark coming from coil. To do this, remove spark plug, hook it up to the coil and set it on motor block and pull it over. You should see a strong spark. If you don't see the spark, then either the coil is faulty or the magnet from coil to flywheel is not getting good contact.
Jul 03, 2009 | Garden
No spark on lawn tractor
have you bypassed the ignition switch?? if you by pass that switch and you get spark you know its the switch
Sep 28, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000 Logo
294 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
