Question about Canon ZR85 Mini DV Digital Camcorder
I have a Canon ZR85. It works fine till a few days ago. When I rewind a tape to recored, it asked me to take out the tape. When I load a tape it makes a ding tone and ejects immediately. It will not allow me to load any tape after. I tried different tapes and fully charged batteries. I tried 1 solution posted here by taking off the battery and reset. It still didn't work. Can you help?
    Brigadier General:
  • 8,619 Answers
Hi
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    It is possible that the tape was damaged that you inserted first. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Please check this CANON ZR85 for more information.
If still the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST).
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 30, 2009
Canon ZR85 Tapes will not go in, it will eject the tape. Why?
Sounds as if your camera has a mechanical problem with the tape loading mechanism. It is possible that it just needs a clean/lube, but otherwise it will need to be repaired or replaced.
Nov 30, 2010 | Canon ZR85 Mini DV Digital Camcorder
Cannon NTSC ZR85 is unable to record video but can view tape on the mini screen. The camera works fine but the screen is blank/black and mic still picks up sound. Would you know a solution
canon has released a service advisory for this condition, its a bad ccd connection, and is offering to fix at no charge. contact canon in your country for details
Oct 07, 2009 | Canon ZR85 Mini DV Digital Camcorder
VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
May 09, 2009 | Sony SLV-940HF VCR
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Tape Playback
Try cleaning the tape heads with a DV tape cleaner and see if that works.
Jul 07, 2008 | Canon ZR800 Mini DV Digital Camcorder
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR85
THE COMPARTMENT IS OF TRACK THIS WILL NEED REPAIR SORRY THIS IS ALOT OF MONEY
Feb 02, 2008 | Canon ZR85 Mini DV Digital Camcorder
Playback mal-function
TRY A CLEANING CASSETTE THIS MIGHT PROLONG THE AGONY. HEAD IS DIRTY OR NEEDS AJUSTED
Jan 09, 2008 | Canon ZR85 Mini DV Digital Camcorder
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
Canon ZR85 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
