Question about Porter Cable Cable Tools 3" X 24" Belt Sander 360
Belt sander 3x24 Porter Cable
The front roller gets gummed up with dust and very hard to clean.
I use a dremmel to clean it but the aluminum on the front roller is being damaged.
any tip on how to clean?
  • bfoisy May 31, 2009
    the gumming is very hard and cannot be removed from a scraper that's why I have to use a dremmel.
    I have tried many types of liquid or solution but no luck.
  • bfoisy Jun 01, 2009
    Yes and still no luck.
  • 285 Answers
Try some "Simple Green" concentrate cleaner, or the "Simple Green" barbecue cleaner in a spray can to clean the roller. Should not use a dremel as you probably know now because of damage.
Another good idea is to blow out the tool after each use with compressed air. An air compressor is a great tool for a lot of things!
Posted on May 31, 2009
  • Dean
    Dean May 31, 2009
    Have you tried throttle body/carburettor cleaner spray?
How do I adjust the porter cable sander so that the belt runs stright?
The porter cable belt sanders have an adjustment knob (threaded screw with a black plastic t-nut on the end). The knob adjusts the angle of one of the rollers and thus the tracking of the belt. The know takes very little adjustment to change the belt's tracking.
Is the know perhaps missing? You can get replacement parts for for porter cable tools at www.servicenet.com.
Hope this helps.
Apr 27, 2011 | Porter Cable Garden
Belt sander tracking cannot be adjusted and further and belt still works its way off the rollers???? Tracking screws is all the way out. Is there any other adjustments
No there is not, I would look for the yoke not pushing forward enough, a bent yoke/roller. Also check the belt and if it is directional make sure installed properly. There might be a buildup of dirt in the platen assembly that needs to be cleaned to allow full travel. Let me know if you need more assistance.
Mar 29, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
My Porter Cable 4" Belt
I would check both rollers for debris on them, also check the plate on the bottom for unusual wear, be careful for sharp edges and make sure the front of the plate is not worn excessively. Then I would turn the front roller without the belt on it to make sure not out of round and moving smoothly. Lastly if you are using directional belts make sure installed properly with the arrow pointing to the front of the sander. Let me know if you need more help before voting and I will see what I can do.
Feb 13, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
I have a porter cable belt sander that shoots dust out the front. It has a dust bag but the wood dust doesn't go in the bag. it used to. I have taped up some weak parts of the bag but I am not sure what...
the inside of the tool is full of dust not allowing it to get into the bag. I have had to completely disassemble and clean the track for the dust. You can try blowing thru every port with compressed air and see if that helps.
Nov 09, 2009 | Porter Cable 3" x 21" Electronic Variable...
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
My porter cable 362 belt sander will not adjust enough to center the belt. When the thumb adj. screw is completely free (lose), it rides about halfway across the roller and stays. I can't bring it back...
The slide arm mechanisms and tension arm, springs, etc. need a little light machine oil, 3-in-1, to make them slide easly, a few dropes will do the trick, do not over oil. Move the adjustment knob just hair at a time or it will over adjust, hope this helps you.
Mar 16, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Smells like wires buning
Motor may just need new brushes, Cooling vents may be clogged with dust. or bearings in the motor or front roller maybe bad. Causing excessive drag
blow it all out with compressed air or shopvac
look for external brush caps (2) oppsite from each other take them out to be sure they slide freely, sometimes one gets hug up and doesn't make good contact
Mar 12, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable Cable Tools 3" X 24" Belt Sander 360 Logo
196 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
